Error trying to set new file into editor [message #142259] |
Tue, 23 October 2007 21:36  |
Originally posted by: andreiberi.look.ca
I am trying to run VE 1.3.0 build on Eclipse 3.3.1 and I am getting the
following error while trying to open a visual class:
"Error trying to set new file into editor. Reason:
java.lang.NullPointerException".
I googled it and it turns out that other people experienced the same
problem on earlier versions of VE.
Anybody has any ideas how to get around this problem?
Andrei
Re: Error trying to set new file into editor [message #142334 is a reply to message #142279] |
Thu, 25 October 2007 13:49  |
Thru the stacktrace, I cannot figure out how this case occurs. I will be
helpful if you can post a testcase.
Yves YANG
http://www.soyatec.com
"Andrei Beri" <andreiberi@look.ca> wrote in message
news:ffp2ci$rk3$1@build.eclipse.org...
>I cleaned all projects and the problem went away. However it is reoccurring
>intermittently.
> What are the current plans for releasing official 1.3 version of VE?
> Here is the stack trace of the exception:
> !ENTRY org.eclipse.ve.java.core 2 0 2007-10-24 22:09:09.609
> !MESSAGE Exception thrown.
> !STACK 0
> at
> org.eclipse.ve.internal.java.codegen.java.AbstractContainerA ddDecoderHelper.getIndexedEntries(AbstractContainerAddDecode rHelper.java:410)
> at
> org.eclipse.ve.internal.swt.codegen.CompositeAddDecoderHelpe r.getIndexPriority(CompositeAddDecoderHelper.java:502)
> at
> org.eclipse.ve.internal.java.codegen.java.ExpressionDecoderH elper.getPriorityOfExpression(ExpressionDecoderHelper.java:1 38)
> at
> org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.determinePriority(AbstractExpressionDecoder.java:67)
> at
> org.eclipse.ve.internal.java.codegen.model.CodeExpressionRef .getPriority(CodeExpressionRef.java:182)
> at
> org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.add ExpressionToSortedList(CodeMethodRef.java:604)
> at
> org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.sor tExpressions(CodeMethodRef.java:702)
> at
> org.eclipse.ve.internal.java.codegen.model.CodeMethodRef.upd ateExpressionOrder(CodeMethodRef.java:710)
> at
> org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createFromJVEModel(ExpressionRefFactory.java:109)
> at
> org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createInitExpression(ExpressionRefFactory.java:74)
> at
> org.eclipse.ve.internal.java.codegen.util.AbstractMethodText Generator.createInitExpression(AbstractMethodTextGenerator.j ava:300)
> at
> org.eclipse.ve.internal.java.codegen.util.AbstractMethodText Generator.generateInLine(AbstractMethodTextGenerator.java:31 7)
> at
> org.eclipse.ve.internal.java.codegen.java.BeanPartFactory.ge nerateLocalVariable(BeanPartFactory.java:78)
> at
> org.eclipse.ve.internal.java.codegen.java.BeanPartFactory.cr eateFromJVEModel(BeanPartFactory.java:670)
> at
> org.eclipse.ve.internal.java.codegen.model.BeanDeclModel.laz yCreateBeanInstance(BeanDeclModel.java:305)
> at
> org.eclipse.ve.internal.java.codegen.model.BeanDeclModel.get ABean(BeanDeclModel.java:324)
> at
> org.eclipse.ve.internal.java.codegen.java.ChildRelationshipD ecoderHelper.getCurrentAddedPart(ChildRelationshipDecoderHel per.java:251)
> at
> org.eclipse.ve.internal.java.codegen.java.ChildRelationshipD ecoderHelper.generate(ChildRelationshipDecoderHelper.java:50 1)
> at
> org.eclipse.ve.internal.java.codegen.java.AbstractExpression Decoder.generate(AbstractExpressionDecoder.java:194)
> at
> org.eclipse.ve.internal.java.codegen.model.CodeExpressionRef .generateSource(CodeExpressionRef.java:361)
> at
> org.eclipse.ve.internal.java.codegen.java.ExpressionRefFacto ry.createFromJVEModel(ExpressionRefFactory.java:102)
> at
> org.eclipse.ve.internal.java.codegen.java.BeanDecoderAdapter .setElement(BeanDecoderAdapter.java:245)
> at
> org.eclipse.ve.internal.java.codegen.java.BeanDecoderAdapter .notifyChanged(BeanDecoderAdapter.java:458)
> at
> org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247)
> at
> org.eclipse.emf.ecore.impl.EStructuralFeatureImpl$InternalSe ttingDelegateSingleEObject.dynamicSet(EStructuralFeatureImpl .java:2425)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicSet(Basi cEObjectImpl.java:1116)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1090)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1061)
> at
> org.eclipse.ve.internal.cde.commands.ApplyAttributeSettingCo mmand.execute(ApplyAttributeSettingCommand.java:70)
> at
> org.eclipse.ve.internal.propertysheet.common.commands.Compou ndCommand.execute(CompoundCommand.java:224)
> at
> at
> org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack$1.run(JavaVisualEditorCommandStack.java:55)
> at
> org.eclipse.ve.internal.cde.core.ModelChangeController.doMod elChanges(ModelChangeController.java:245)
> at
> org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack.execute(JavaVisualEditorCommandStack.java:5 2)
> at
> org.eclipse.ve.internal.swt.GridLayoutComponentPage.execute( GridLayoutComponentPage.java:866)
> at
> org.eclipse.ve.internal.swt.GridLayoutComponentPage$GrabActi on.run(GridLayoutComponentPage.java:470)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
> at
> org.eclipse.jface.action.ActionContributionItem$4.handleEven t(ActionContributionItem.java:375)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
> Andrei
> Yves YANG wrote:
>> Please give more information such as stacktrace or a test-case ! It is
>> hard to guess what is wrong.
>> Best regards
>> Yves YANG
>> eFace: XAML for java (http://www.soyatec.com)
>> news:ffm7ia$c8r$1@build.eclipse.org...
>>> Thanks,
>>> Andrei
Re: Error trying to set new file into editor [message #616800 is a reply to message #142259] |
Wed, 24 October 2007 06:03  |
Please give more information such as stacktrace or a test-case ! It is hard
Best regards
Yves YANG
> Andrei
Re: Error trying to set new file into editor [message #616801 is a reply to message #142269] |
Wed, 24 October 2007 23:26  |
reoccurring intermittently.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Andrei
> Best regards
> Yves YANG
>> Thanks,
>> Andrei
Re: Error trying to set new file into editor [message #616806 is a reply to message #142279] |
Yves YANG
>intermittently.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Andrei
>> Best regards
>> Yves YANG
>>> Thanks,
>>> Andrei
FUDForum. Page generated in 1.11225 seconds
