Home » Archived » Visual Editor (VE) » Designing Swing Applications on Eclipse
Designing Swing Applications on Eclipse [message #142218] Tue, 23 October 2007 11:35 Go to next message
Originally posted by: njagan.gmail.com
Hi all,
I have Eclipse 3.3 (Europa) installed on my PC, and I'm running Java 6.
Can someone guide me on how to design swing applications using Eclipse
3.3? (Please note: SWING NOT SWT).
I could do this when I had Eclipse 3.1 & 3.2 installed. But, starting
Eclipse 3.3 I am not able to bring up the Swing designer. To add to this,
I am not able to locate the following:
(1) New->Examples->Swing->Slider Game
(2) Window > Preferences > Java > Visual Editor (This is per the VE Help
file. I know I could do this in my previous installation of Eclipse, but I
cannot do even this simple thing anymore).
Please help. I'm going crazy.
Thanks for your time and help folks!
Re: Designing Swing Applications on Eclipse [message #142230 is a reply to message #142218] Tue, 23 October 2007 14:06 Go to previous messageGo to next message
Ok, I did the only thing that was possible... reinstall everything from
scratch. Probably my plug-ins were corrupted. I manually re-installed EMF,
GEF & VE.
Now I can create a Visual Class. But, when the palette loads I get the
following error message: "An internal error occurred during: "Setup Java
Visual Editor".
org/eclipse/jem/internal/proxy/initParser/tree/NoExpressionV alueException "
Any help would be appreciated. Thanks.
Re: Designing Swing Applications on Eclipse [message #142247 is a reply to message #142230] Tue, 23 October 2007 18:56 Go to previous messageGo to next message
I don't work on VE for Eclipse 3.3 yet. In general this kind of problem may
be relative of the cache.
I suggest to reset the cache: in the file explorer, try to find all files
named as ".cache" under the workspace and delete them.
best regards
yves yang
eFace: XAML for java (http://www.soyatec.com/eface)
"Jagan Nambi" <njagan@gmail.com> wrote in message
news:defa44b4a24a8581b6de424c4f8e0ceb$1@www.eclipse.org...
> GEF & VE.
> Visual Editor".
Re: Designing Swing Applications on Eclipse [message #142299 is a reply to message #142247] Thu, 25 October 2007 09:45 Go to previous message
Thanks. Actually, there's a wonderful posting by Chris Dolan that I
followed step-by-step. I needed to install a certain patch of VE for
Eclipse 3.3. That helped solve my problems.
Re: Designing Swing Applications on Eclipse [message #616796 is a reply to message #142218] Tue, 23 October 2007 14:06 Go to previous message
GEF & VE.
Visual Editor".
Re: Designing Swing Applications on Eclipse [message #616798 is a reply to message #142230] Tue, 23 October 2007 18:56 Go to previous message
best regards
yves yang
> GEF & VE.
> Visual Editor".
Re: Designing Swing Applications on Eclipse [message #616803 is a reply to message #142247] Thu, 25 October 2007 09:45 Go to previous message
Previous Topic:Updated patched VE for 3.3/Europa
Next Topic:Visual Editor 1.2 not usable in Eclipse 3.2.2
Current Time: Wed Jul 23 08:54:30 EDT 2025
Powered by FUDForum. Page generated in 0.07892 seconds
