Home » Eclipse Projects » Eclipse Platform » Selective default of a Quick Diff provider
Selective default of a Quick Diff provider [message #141942] Thu, 09 October 2003 17:46 Go to next message
Originally posted by: matt_conway.nospam.i2.com
I've written a quick diff provider for my clearcase (team) plugin.
Everything works fine, except it is annoying to have to right click in
the ruler for every file I open.
I tried setting my provider as the default in
Window->Preferences->workbench->Editors->Quick Diff, but that didn't
seem to have any effect (eclipse 3.0 build 200309250800)
It would be nice if I could somehow selectively set my provider as the
default for files of certain type so that I could still use the version
on disk provider when it is a better fit.
Is there any way to do this? Thanks,
Matt
Re: Selective default of a Quick Diff provider [message #141991 is a reply to message #141942] Fri, 10 October 2003 02:47 Go to previous messageGo to next message
Thats the correct setting, but only for the Text editor... the Java
Editor still has its own preferences (I know...), for the quick diff
provider see Java->Work in Progress
-tom
Re: Selective default of a Quick Diff provider [message #142278 is a reply to message #141991] Fri, 10 October 2003 10:39 Go to previous messageGo to next message
Ah, ok, I see - that did the trick.
I still have to do this for other non-java/non-text editors (e.g. ant
editor), but the frequency has been greatly dimished =)
Matt
Re: Selective default of a Quick Diff provider [message #142684 is a reply to message #142278] Sun, 12 October 2003 00:21 Go to previous messageGo to next message
Wouldn't the following enhancement request do it for you:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37162
(But it is in jdt/ui and maybe it should be solved not only
for the issue described in it. Maybe you can comment on it)
Cheers
Steve
Re: Selective default of a Quick Diff provider [message #143154 is a reply to message #142684] Mon, 13 October 2003 13:22 Go to previous message
That bug seems to be related to Quick Fix, not Quick Diff - did you mean
to point to a different one?
Matt
Previous Topic:wizard and wizardpages passing objects
Next Topic:EMF file access outside of workbench
Current Time: Fri Nov 07 21:29:14 EST 2025
Powered by FUDForum. Page generated in 0.03703 seconds
