"An error occured when connecting to the host." [message #142229] |
Wed, 20 May 2009 20:06  |
I'm using Eclipse 3.4.2 on Windows with JDK 1.5.
I installed TPTP packages using Help > Software Update.
I quit Eclipse and restarted with with -clean.
Then I chose a program, right-click on it, choose \
Profile> Profile As > Profile Configuration.
There is an error message near the top of Profile Configurations
window that reads "[Monitor]: The launch requires
at least one data collector to be selected."
I found a similar report in this forum but my case is
a little bit different. The Monitor tab has a red X.
If I click on the tab, there is another error message that reads:
IWAT0435E An error occured when connecting to the host.
metadata/.log doesn't record relevant errors.
Am I missing some components?
Re: "An error occured when connecting to the host." [message #142388 is a reply to message #142258] |
Mon, 01 June 2009 10:00  |
This is a multipart message in MIME format.
--=_alternative 004D1789852575C8_=
Content-Type: text/plain; charset="US-ASCII"
Hi Kuro,
Can you check if you have a serviceconfig.xml configured in your
workspace\.metadata\.plugins\org.eclipse.tptp.platform.iac.a dministrator\config?
This is the serviceconfig.xml used by the Integrated Agent Controller
(IAC), while the one in the plug-in's config folder can be empty. Can you
post the serviceconfig.xml contents?
Prior to launching the profile configuration, is there an ACServer.exe
process running? Once you launch the profile configuration dialog, does
the ACServer.exe process start?
Joel
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi Kuro,</font>
<br>
<br><font size=2 face="sans-serif">Can you check if you have a serviceconfig.xml
configured in your workspace\.metadata\.plugins\org.eclipse.tptp.platform.iac.a dministrator\config?
This is the serviceconfig.xml used by the Integrated Agent Controller (IAC),
while the one in the plug-in's config folder can be empty. Can you post
the serviceconfig.xml contents?</font>
<br>
<br><font size=2 face="sans-serif">Prior to launching the profile configuration,
is there an ACServer.exe process running? Once you launch the profile configuration
dialog, does the ACServer.exe process start?</font>
<br>
<br><font size=2 face="sans-serif">Best regards,</font>
<br><font size=2 face="sans-serif">Joel</font>
--=_alternative 004D1789852575C8_=--
FUDForum. Page generated in 0.03694 seconds
