Home » Archived » Test and Performance Tools Platform (TPTP) » "An error occured when connecting to the host."
"An error occured when connecting to the host." [message #142229] Wed, 20 May 2009 20:06 Go to next message
I'm using Eclipse 3.4.2 on Windows with JDK 1.5.
I installed TPTP packages using Help > Software Update.
I quit Eclipse and restarted with with -clean.
Then I chose a program, right-click on it, choose \
Profile> Profile As > Profile Configuration.
There is an error message near the top of Profile Configurations
window that reads "[Monitor]: The launch requires
at least one data collector to be selected."
I found a similar report in this forum but my case is
a little bit different. The Monitor tab has a red X.
If I click on the tab, there is another error message that reads:
IWAT0435E An error occured when connecting to the host.
metadata/.log doesn't record relevant errors.
Am I missing some components?
Re: "An error occured when connecting to the host." [message #142240 is a reply to message #142229] Wed, 20 May 2009 20:07 Go to previous messageGo to next message
I forgot to mention that the Monitor tab has no item listed.
Re: "An error occured when connecting to the host." [message #142249 is a reply to message #142240] Thu, 21 May 2009 14:18 Go to previous messageGo to next message
Someone told me to install an Agent Controller.
I did that and started ACServer.exe.
Then I do see "Java Profiling" and other agents in the Monitor tab.
But when I click on "Test Availability" I got this error message:
The JVMTI agent org.eclipse.tptp.jvmti is not available.
When I hit "Test Connection" in Preferences's Agent Controller -> Hosts
the connection succeeds.
What plugin do I need to get?
Re: "An error occured when connecting to the host." [message #142258 is a reply to message #142249] Fri, 22 May 2009 13:45 Go to previous messageGo to next message
I've just read this help page that says an independent Agent Controller
program is not needed for profiling a program locally.
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. tptp.platform.agentcontroller.doc.user/concepts/ac/ciacintro .html
So I stopped the Agent Controller service (I'm on Windows) and tried to
follow the instructions here:
but the Monitor tab is empty with an error message in red:
IWATO435E An error occured when connecting to the host.
I think that IAC failed to start automatically.
I also found that the only serviceconfig.xml that exists in my eclipse
installation is:
/plugins/org.eclipse.tptp.platform.ac.win_ia32_4.4.100.v2009 02101418/agent_controller/config/serviceconfig.xml
and its contents is only:
<PluginConfiguration>
</PluginConfiguration>
Is this expected?
Re: "An error occured when connecting to the host." [message #142388 is a reply to message #142258] Mon, 01 June 2009 10:00 Go to previous message
This is a multipart message in MIME format.
--=_alternative 004D1789852575C8_=
Content-Type: text/plain; charset="US-ASCII"
Hi Kuro,
Can you check if you have a serviceconfig.xml configured in your
workspace\.metadata\.plugins\org.eclipse.tptp.platform.iac.a dministrator\config?
This is the serviceconfig.xml used by the Integrated Agent Controller
(IAC), while the one in the plug-in's config folder can be empty. Can you
post the serviceconfig.xml contents?
Prior to launching the profile configuration, is there an ACServer.exe
process running? Once you launch the profile configuration dialog, does
the ACServer.exe process start?
Joel
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi Kuro,</font>
<br>
<br><font size=2 face="sans-serif">Can you check if you have a serviceconfig.xml
configured in your workspace\.metadata\.plugins\org.eclipse.tptp.platform.iac.a dministrator\config?
This is the serviceconfig.xml used by the Integrated Agent Controller (IAC),
while the one in the plug-in's config folder can be empty. Can you post
the serviceconfig.xml contents?</font>
<br>
<br><font size=2 face="sans-serif">Prior to launching the profile configuration,
is there an ACServer.exe process running? Once you launch the profile configuration
dialog, does the ACServer.exe process start?</font>
<br>
<br><font size=2 face="sans-serif">Best regards,</font>
<br><font size=2 face="sans-serif">Joel</font>
--=_alternative 004D1789852575C8_=--
Previous Topic:Can't find data collectors
Next Topic:tptp 4.5.2 and jboss 5
Current Time: Sat Jul 26 11:32:52 EDT 2025
Powered by FUDForum. Page generated in 0.04291 seconds
