Metameta modeling with EMF? [message #1422242] |
Fri, 12 September 2014 10:44  |
I have been stumbling with this issue for some time now and I don't think I can pursue it any further by myself and decided to kindly ask for your help.
Here is my problem: I am creating a business process metamodel (MA): flownodes (eg. activities, events...) each referencing a nextAction and previousAction flownode reference, constraints, inputs/outputs, etc. From metamodel MA, I want to create an instance (MB) that, say, have activity "Prepare order", followed by (i.e. nextAction=) "Ship Order", followed by "Receive Payment". "Prepare order" has one input object of type "Order" and 1..* objects of type Product and one output object of type Package.
(Note.: Order, Product and Package are EClasses from another ecore model serving as the informational model, that I include)
What I am trying to achieve it this:
1. I create the MA ecore metamodel;
2. Using MA's editor, I want to create MB model that I could save as an ecore file
3. Using MB's ecore, I generate java code and editors to create concrete instances of MB.
One way I was able to do that is by:
- Create an MA.ecore
- Create an MB model and include MA. Each activity has FlowNode as its super type.
- Generate the code and create instances of MB
This works fine but not in an elegant way: I have no way to enforce that an instance of "PrepareOrder" must have a an instance of "ShipOrder" since I cannot redeclare the "nextAction" feature. Sure I can do that with OCL but that is still not elegant enough for me (e.g. in the editor, the nextAction dropdown will give me all the FlowNode instances).
I hope this problem makes sense to you guys and you could point me to the right direction, or at least confirm that I shouldn't persue this. My problem generalizes as: is it possible to metametamodel with EMF? That is going from an ecore to generate an ecore?
Thanks for your help!
Anis
Re: Metameta modeling with EMF? [message #1422308 is a reply to message #1422242] |
Fri, 12 September 2014 12:57  |
As you've discovered, EMF supports structural metamodeling and that is
not enough. For more interesting metamodels you need constraints.
If you use UML you can express the constraints as OCL within Stereotypes.
In EMF, you can use the OCL->Load Resource to load additional
constraints that will apply during Validate / OCL->Validate. See the
Complete OCL tutorial.
The Sample Ecore Editor is just that, a sample. If you want to exploit
your constraints to affect the menu entries feel free to contribute an
enhancement.
Ed Willink
On 12/09/2014 15:44, Poissy B. wrote:
> Hello,
> for your help.
> type Package. (Note.: Order, Product and Package are EClasses from
> What I am trying to achieve it this: 1. I create the MA ecore metamodel;
> ecore file
> instances of MB.
> One way I was able to do that is by: - Create an MA.ecore
> super type. - Generate the code and create instances of MB
> Anis
FUDForum. Page generated in 0.04309 seconds
