Home » Archived » EMF-IncQuery » how load xml emf resource using api
how load xml emf resource using api [message #1422119] Fri, 12 September 2014 06:57 Go to next message
Hi ! How can I load the xml emf resource in order to call the queries using EMF IncQuery API ? I do not find anywhere . Thank you !
Re: how load xml emf resource using api [message #1422207 is a reply to message #1422119] Fri, 12 September 2014 09:45 Go to previous messageGo to next message
Which "xml emf resource" do you mean? The one that contains the EMF instance model, the contents of which you wish to query?
If so, you can use the standard EMF API to instantiate a ResourceSet and use it to load the Resource. This is a general mechanism of EMF, not specific to EMF-IncQuery.
Hope that helps,
Gábor
Re: how load xml emf resource using api [message #1422213 is a reply to message #1422207] Fri, 12 September 2014 09:54 Go to previous messageGo to next message
Yes . So , I loaded the instance model , but how can I query on this model ? I managed through API to load the model , the .eiq file , to get its content , but I am stuck here . I am sorry , I really can't understand . I used IncQueryHeadlessAdvanced for headless example.
Re: how load xml emf resource using api [message #1422227 is a reply to message #1422213] Fri, 12 September 2014 10:19 Go to previous messageGo to next message
Made Leine wrote on Fri, 12 September 2014 15:54
I recommend reading the Javadoc of IncQueryEngine.
You should use e.g. IncQueryEngine.on(myResourceSet) to obtain an IncQuery instance that can evaluate queries against the model in the given resource set. You can then obtain Matcher objects associated with individual query specifications.
Well, this example method takes a parameter fileURI, which should be the URI of the instance model. However, you should not call this method, but rather read its code Smile
The headless example code, as well as its advanced version, is meant as a code example for you to read, in order to demonstrate the usage of the EMF-IncQuery API. It is not the API itself, it merely uses the API in one specific way. If you read the code, I believe it will be easy to follow.
I hope this clears it up for you,
Gábor
Re: how load xml emf resource using api [message #1422230 is a reply to message #1422227] Fri, 12 September 2014 10:23 Go to previous messageGo to next message
I would add that it is better to look at the Usage examples part of the documentation: https://wiki.eclipse.org/EMFIncQuery/UserDocumentation/API#Typical_programming_patterns
It contains several different examples about using the IncQuery runtime API.
Zoltán
Re: how load xml emf resource using api [message #1423871 is a reply to message #1422230] Mon, 15 September 2014 01:28 Go to previous message
Thank you so much for the answers!
I was giving as a parameter to IncQueryEngine.on(resource) the path to the ecore file . Now I understand.
Previous Topic:call queries IncQuery API
Next Topic:Duplication issue of Item and Edge in Zest graph
Current Time: Sat Jul 26 11:14:30 EDT 2025
Powered by FUDForum. Page generated in 0.09142 seconds
