Home » Eclipse Projects » GEF » ConnectionLayer
ConnectionLayer [message #142198] Fri, 09 July 2004 06:08 Go to next message
Originally posted by: sergeyv.offshorecreations.com
Hello
I need to draw figures on front layer and connections on back layer. The
default order of printable layers of ScalableFreeformRootEditPart is
PRIMARY_LAYER and then CONNECTION_LAYER. I changed the order of the layers
(see code below) but now my connections are invisible. Why?
public class MyRootEditPart extends ScalableFreeformRootEditPart {
protected LayeredPane createPrintableLayers() {
FreeformLayeredPane layeredPane = new FreeformLayeredPane();
layeredPane.add(new ConnectionLayer(), CONNECTION_LAYER);
layeredPane.add(new FreeformLayer(), PRIMARY_LAYER);
return layeredPane;
} //createPrintableLayers
} //class MyRootEditPart
With Best Regards
Vyunnikov Sergey
Offshore Creations, Inc.
www.OffshoreCreations.com
Re: ConnectionLayer [message #142219 is a reply to message #142198] Fri, 09 July 2004 08:17 Go to previous messageGo to next message
Originally posted by: rlemaigr.ulb.ac.be
Maybe the background figure of the primary layer was opaque and when you=
switch the layers it hides the connection layer ?
I looks to simple to be true but who knows...
r=E9gis
On Fri, 9 Jul 2004 13:08:25 +0300, Sergey Vyunnikov =
<sergeyv@offshorecreations.com> wrote:
> Hello
> I need to draw figures on front layer and connections on back layer. T=
he
> PRIMARY_LAYER and then CONNECTION_LAYER. I changed the order of the =
> layers
> FreeformLayeredPane layeredPane =3D new FreeformLayeredPane();=
> return layeredPane;
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: ConnectionLayer [message #142256 is a reply to message #142219] Fri, 09 July 2004 08:58 Go to previous messageGo to next message
The function setOpaque(false) does not solve this problem.
With Best Regards
Vyunnikov Sergey
<rlemaigr@ulb.ac.be> wrote in message
news:opsavdqqkoxn9g2u@xn--pcrgis-dva.mshome.net...
r
Re: ConnectionLayer [message #142643 is a reply to message #142256] Tue, 13 July 2004 15:42 Go to previous messageGo to next message
On what figure did you invoke setOpaque(false)? The figure returned by your
base EditPart needs to be transparent as well, not just the layer.
"Sergey Vyunnikov" <sergeyv@offshorecreations.com> wrote in message
news:ccm4og$o32$1@eclipse.org...
> With Best Regards
> Vyunnikov Sergey
> Hello,
> r
Re: ConnectionLayer [message #142727 is a reply to message #142643] Wed, 14 July 2004 04:52 Go to previous messageGo to next message
Thanks. It works :)
With Best Regards
Vyunnikov Sergey
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cd1ds9$s7e$1@eclipse.org...
your
Re: ConnectionLayer [message #170176 is a reply to message #142643] Wed, 02 March 2005 07:53 Go to previous message
Hello!
I ran into the same problem as Sergey did, unfortunately I still cannot see
my connections after having changed
primary and connection layer and I cannot see which layer or edit part is
still opaque.
In my ScalableRootEditPart extension, I overrode the following and changed
the layer order.
LayeredPane pane = new LayeredPane();
Layer layer = new ConnectionLayer();
layer.setPreferredSize(new Dimension(5, 5));
layer.setBackgroundColor(MyColorConstants.COLOR_ORANGE);
pane.add(layer, CONNECTION_LAYER);
layer = new Layer();
layer.setOpaque(false);
layer.setBackgroundColor(MyColorConstants.COLOR_GREEN);
layer.setLayoutManager(new StackLayout());
pane.add(layer, PRIMARY_LAYER);
return pane;
Additionally, I added some System.out.println in the ScalableRootEditPart's
methods
getContents() and getContentPane() in order to get an output in case one of
the figures returned here are opaque.
public EditPart getContents() {
if (contents instanceof GraphicalEditPart) {
if (((GraphicalEditPart)contents).getFigure().isOpaque())
System.out.println("contents-figure is opaque");
return contents;
/* (non-Javadoc)
* @see org.eclipse.gef.GraphicalEditPart#getContentPane()
public IFigure getContentPane() {
IFigure l = getLayer(PRIMARY_LAYER);
if(l.isOpaque())
System.out.println("layer is opaque");
return l;
None of these figures turn out to be opaque, so, something goes wrong with
my layer order ?
In my editor, things look like the following layer/edit parts order
(see also attached screenshots)
- gef_ng1.gif: I colored the layers - connection_layer: orange,
primary_layer:green (connections hidden)
(from top to bottom)
1) the model root element's children edit parts (except for the connections,
of course)
2) My Model Root Edit Part (which has no BGCOLOR and is not opaque) -
returned by ScalableRootEditPart#getContents()
3) PRIMARY_LAYER - what's returned by ScalableRootEditPart#getContentPane()
4) CONNECTION_LAYER (orange)
in gef_ng2.gif is the initial state with default order - bottom:
primary_layer, above: connection_layer -> connections above child edit
parts, I try to get them below th child edit parts...
I wonder, how I can get the primary layer (3) opaque (isn't it opaque when
my System.outs coding is never reached?).
Actually, I want the connections between 1) and 2)
Or did I misunderstand sth. and 2) is equals 3) ? Anyway, does anyone of you
see where's my problem?
Thanks a lot and best regards,
Marion
your
> > With Best Regards
> > Vyunnikov Sergey
> > Hello,
> > r
  • Attachment: gef_ng2.gif
    (Size: 4.27KB, Downloaded 101 times)
  • Attachment: gef_ng1.gif
    (Size: 3.07KB, Downloaded 108 times)
Previous Topic:Command safety tip and debugging tip
Next Topic:org.eclipse.ui.PlatformUI
Current Time: Sat Jul 19 04:27:02 EDT 2025
Powered by FUDForum. Page generated in 0.03996 seconds
