Home » Modeling » TMF (Xtext) » [solved] [Xbase] java like variable declaration
[solved] [Xbase] java like variable declaration [message #1421470] Thu, 11 September 2014 08:11 Go to next message
I want to use XBase as expression language and shrank it to fit my needs. Now I have a problem and can't find a way to fix it. For variable declaration XBase has the rule
VariableDeclaration returns Expression:
	{VariableDeclaration}
	'def' (=>  (type=JvmTypeReference name=ValidID) | name=ValidID) ('=' right=Expression)?
But I don't want to use def as keyword. I'd like to write things like
int value = 15
value = 13
Atm the code above is interpreted as "int" is a FeatureCall and "value=15" is an Assignment, but "int value = 15" as whole should be an Assignment. When I delete "def" in the rule I get an error message while running the generator. I didn't touch anything, just shrank the XBase code.
[Updated on: Thu, 11 September 2014 09:09] by Moderator
Re: [Xbas] java like variable declaration [message #1421474 is a reply to message #1421470] Thu, 11 September 2014 08:17 Go to previous messageGo to next message
the problem is that without the var keyword the grammar is amgibous i think
Re: [Xbas] java like variable declaration [message #1421475 is a reply to message #1421474] Thu, 11 September 2014 08:19 Go to previous messageGo to next message
https://www.eclipse.org/forums/index.php/m/1367389/?srch=xvariabledeclaration#msg_1367389
Re: [Xbas] java like variable declaration [message #1421509 is a reply to message #1421475] Thu, 11 September 2014 09:09 Go to previous message
Danke.
EDIT: I mean thank you Smile
[Updated on: Thu, 11 September 2014 09:10] by Moderator
Previous Topic:xcore, ecore, emf, xtext and maven
Next Topic:XText - Cannot load model in standalone setup
Current Time: Mon Jul 21 03:39:33 EDT 2025
Powered by FUDForum. Page generated in 0.31715 seconds
