Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP
TPTP [message #142072] Tue, 28 April 2009 06:08 Go to next message
Is console output can be used for verification by selection for TPTP
Automatic GUI Recording?
Ganeshraj.S
Re: TPTP [message #142078 is a reply to message #142072] Tue, 28 April 2009 06:16 Go to previous messageGo to next message
Hi Ganesh,
Yes. You will create a verification point on the Console view and
verify the content in the text field.
Paul
"Ganesh " <ganesh.vibrant@gmail.com> wrote in message
news:c4fd857a380cf4e3d23cf67df09e2a69$1@www.eclipse.org...
> Ganeshraj.S
Re: TPTP [message #142096 is a reply to message #142078] Tue, 28 April 2009 06:43 Go to previous messageGo to next message
Hi Paul,
Is there any demo for verification by selection mechanism? It will really
useful for us to migrate to eclipse TPTP.
Thanks in advance!
Ganeshraj.S
Re: TPTP [message #142119 is a reply to message #142096] Wed, 29 April 2009 06:01 Go to previous messageGo to next message
Hi Ganesh,
Yes, please see
http://www.eclipse.org/tptp/test/documents/gettingstarted/Au tomated_GUI_Recorder_Getting_Started.html#3.0.
Paul
news:aeedeee3f8dc9b474f24e702ecb93f17$1@www.eclipse.org...
> Hi Paul,
> Thanks in advance!
> Ganeshraj.S
Re: TPTP [message #142125 is a reply to message #142119] Thu, 30 April 2009 05:14 Go to previous messageGo to next message
Thanks for the demo, but this demo doesn't talks about how to use
"Verification by selection" mechanism.
For my test case, I want to check the console output whenever the test
case is running. While recording the test case is that I should just
select the text in the console window(How to make TPTP understand about
that it should check the text which I select)? TPTP will automatically
record my selection and check whenever the test case is running?
If I select the console window for the text need to be checked following
is the xml entry which was made,
<command descriptive=" rm -f Car; /opt/aCC/bin/aCC -o Car +Z
-D_HPUX_SO..." type="focus" referenceId="107"/>
I dont think this is getting checked whenever test case is running. Am I
using verification by selction mechanism correctly. Document on
verification by selection mechanism is not clear. If I am able to proceed
with this I can help eclipse.org in updating those documents(with my
experience in using AGR).
Thanks in advance for your help!
Ganeshraj.S
Re: TPTP [message #142131 is a reply to message #142125] Fri, 01 May 2009 06:29 Go to previous messageGo to next message
Hi Ganesh,
I am afraid the only AGR resources are listed in
For adding a verification hook, click the verification hook button in the
AGR recorder toolbar and select the console view with your mouse. The
verification hook method will then be created in your test class, which
requires the code to inspect the parameter ViewPart for the console output.
Please keep in mind that the AGR is an as-is component (see
http://wiki.eclipse.org/4.5_Component_Reorganization#Compone nt_Classifications).
We would certainly appreciate any updates to the AGR documentation.
Paul
news:dbd94328d5c36a2a6642778af91d0ffd$1@www.eclipse.org...
> "Verification by selection" mechanism. For my test case, I want to check
> the console output whenever the test case is running. While recording the
> test case is that I should just select the text in the console window(How
> to make TPTP understand about that it should check the text which I
> select)? TPTP will automatically record my selection and check whenever
> +Z -D_HPUX_SO..." type="focus" referenceId="107"/>
> Ganeshraj.S
Re: TPTP [message #142136 is a reply to message #142131] Wed, 06 May 2009 05:31 Go to previous messageGo to next message
I need to get the content of console view from IViewPart object. please
let me know how to get it? or point me to the place where I can get help
for this.
Ganeshraj.S
Re: TPTP [message #142142 is a reply to message #142136] Wed, 06 May 2009 06:21 Go to previous messageGo to next message
Hi Ganesh,
Please see the responses to your thread named 'TPTP-verification
machanisms'.
Paul
news:dd14710377bd43eab9eb96dd4b33ac64$1@www.eclipse.org...
> for this.
> Ganeshraj.S
Re: TPTP [message #142171 is a reply to message #142142] Fri, 08 May 2009 07:06 Go to previous messageGo to next message
Thanks Paul for all your replies :)
It will be really useful if we see more examples on AGR- VERIFICATION
MECHANISMS.
Is there any already written test cases available?
Once again thanks for your help!
Ganeshraj.S
Re: TPTP [message #142211 is a reply to message #142171] Tue, 19 May 2009 07:01 Go to previous message
Hi Ganesh,
Sorry, no.
Paul
news:effc511a748360511ca532751e1a5475$1@www.eclipse.org...
> MECHANISMS.
> Ganeshraj.S
Previous Topic:TPTP with Eclipse Ganymede using Linux
Next Topic:Verification Class
Current Time: Fri Nov 07 00:37:45 EST 2025
Powered by FUDForum. Page generated in 0.05231 seconds
