Home » Modeling » TMF (Xtext) » XText - Cannot load model in standalone setup(Guice related exception)
icon5.gif  XText - Cannot load model in standalone setup [message #1419362] Mon, 08 September 2014 09:42 Go to next message
Hi Joerg and everyone,
I have defined a language to define conditional expressions using XText. The generated editor works fine that should indicate the parser and other components are valid. I want to use ONLY the parser in my scenario and I followed the instructions at http://wiki.eclipse.org/Xtext/FAQ#Why_do_I_get_compilation_errors_when_trying_to_import_an_existing_Xtext_grammar_using_the_with_statement.3F
Here is my code of Unit test (written in Xtend):
import uk.ac.man.xman.dsl.ConditionDSLStandaloneSetup
@RunWith(XtextRunner)
class ParsingText {
       @Test
       def void parseSampleText () {
               new StandaloneSetup().setPlatformUri("../");
                val injector = new ConditionDSLStandaloneSetup().createInjectorAndDoEMFRegistration();
                val resourceSet = injector.getInstance(typeof(XtextResourceSet));
                resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
                val uri  = URI.createURI("dummy:/example.cdsl")
                val resource = resourceSet.createResource(uri); //ERROR happened here
                val in = new ByteArrayInputStream("((id1 == 1) && (id2 == 2))".getBytes());
                resource.load(in, resourceSet.getLoadOptions());
However, I faced an exception:
com.google.inject.ProvisionException: Guice provision errors:
1) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: java.lang.ArrayIndexOutOfBoundsException: 3
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.<init>(Unknown Source)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.class(Unknown Source)
while locating org.eclipse.xtext.common.services.TerminalsGrammarAccess
for parameter 1 at uk.ac.man.xman.dsl.services.ConditionDSLGrammarAccess.<init>(Unknown Source)
at uk.ac.man.xman.dsl.services.ConditionDSLGrammarAccess.class(Unknown Source)
while locating uk.ac.man.xman.dsl.services.ConditionDSLGrammarAccess
while locating org.eclipse.xtext.IGrammarAccess
for field at org.eclipse.xtext.linking.lazy.LazyLinker.grammarAccess(Unknown Source)
while locating org.eclipse.xtext.linking.lazy.LazyLinker
while locating org.eclipse.xtext.linking.ILinker
for field at org.eclipse.xtext.resource.XtextResource.linker(Unknown Source)
while locating org.eclipse.xtext.linking.lazy.LazyLinkingResource
while locating org.eclipse.xtext.resource.XtextResource
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.ArrayIndexOutOfBoundsException: 3
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:57)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadGrammarFile(BaseEPackageAccess.java:44)
at org.eclipse.xtext.service.GrammarProvider.getGrammar(GrammarProvider.java:60)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.internalFindGrammar(TerminalsGrammarAccess.java:37)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.<init>(TerminalsGrammarAccess.java:33)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
Any idea why this happened? Your help is appreciated.
Re: XText - Cannot load model in standalone setup [message #1420245 is a reply to message #1419362] Tue, 09 September 2014 14:30 Go to previous messageGo to next message
i cannot reproduce that. do you have any customizations in your dsl? where did you place the test.
btw testing is more easy like that if you use the parseHelper class (and yourdslinjectorprovider)
Re: XText - Cannot load model in standalone setup [message #1420253 is a reply to message #1420245] Tue, 09 September 2014 14:41 Go to previous messageGo to next message
Christian,
Thanks for your reply. My language is actually simple.
Here is my language definition:
grammar uk.ac.man.xman.dsl.ConditionDSL with org.eclipse.xtext.common.Terminals
generate conditionDSL "www.ac.uk/xman/dsl/ConditionDSL"
Model:
	expression=Expression;
Expression:
	CompositeExpression;
CompositeExpression returns Expression:
	PrimaryExpression (({AND.left=current} '&&' | {OR.left=current} '||') right=PrimaryExpression)*;
PrimaryExpression returns Expression:
	{PrimaryExpression} ('(' e=Expression ')' |
	 name=ID Operator INT | FLOAT | STRING) |
	 Constant;
Constant:
	value = '.';
FLOAT:
	INT '.' INT;
Operator:
Is this enough for inspection? I could even upload my projects if it helps.
You seemed to suggest the exception has relation to my language. But the (generated) editor runs fine though.
My test was placed in the test project which was automatically created when I started my DSL project (using Wizard).
I also tried parseHelper and ...injectorprovider but I encountered similar exception.
[Updated on: Tue, 09 September 2014 14:41] by Moderator
Re: XText - Cannot load model in standalone setup [message #1420254 is a reply to message #1420253] Tue, 09 September 2014 14:43 Go to previous messageGo to next message
Please note there is "http://" preceding "www.ac.uk/xman/dsl/ConditionDSL" . I was not allowed to put the full URL in my post.
Re: XText - Cannot load model in standalone setup [message #1420258 is a reply to message #1420254] Tue, 09 September 2014 14:45 Go to previous messageGo to next message
hi,
works fine with your grammar too.
Re: XText - Cannot load model in standalone setup [message #1420261 is a reply to message #1420258] Tue, 09 September 2014 14:53 Go to previous messageGo to next message
can you try to recreate the project in a different workspace?
which xtext version / os / jdk do you use?
Re: XText - Cannot load model in standalone setup [message #1421987 is a reply to message #1420261] Fri, 12 September 2014 02:33 Go to previous message
Hi Christian,
I actually had tried what you suggested before reading your reply. Surprisingly (to me at least), it worked. I think the problem was caused by my own mistake when I chose to run Generate XText artefacts. I used Kepler with Xtext 2.4.3 to create my language and although the MWE2 workflow (to generate artifacts) completed, there was an error (see below).
error(10):  internal error: Can't get property indirectDelegates using method get/isIndirectDelegates from org.antlr.tool.Grammar instance : java.lang.NullPointerException
I thought the generated artifacts were unusable and looked for a solution to get rid of the above error. I read somewhere this error exists in old Xtext (2.4.x) and hence I decided to use Luna with Xtext 2.6.x to generate Xtext artifacts. Generation was successful without errors. So, I went on using those generated stuff in Kepler because I also use Spray that requires Xtext 2.4.x.
Today, I used Kepler and ignored the error and discovered everything was ok.
Many thanks to you (Christian) for your time and support anyway. Hope my experience will help someone.
[Updated on: Fri, 12 September 2014 02:34] by Moderator
Previous Topic:[solved] [Xbase] java like variable declaration
Next Topic:xtext 2.4.1 in eclipse luna
Current Time: Wed Jul 23 23:33:27 EDT 2025
Powered by FUDForum. Page generated in 0.08522 seconds
