Re: Creating Connectors for a UML Component like diagram [message #1421514 is a reply to message #1420072] |
Thu, 11 September 2014 09:12  |
You can find a sample to display rotatable node in UML Designer. Import
the plugin org.obeonetwork.gmf.runtime.diagram.ui.extension. You will
find usefull information/example in RotatableNodeEditPart and the whole
package org.obeonetwork.gmf.runtime.diagram.ui.extension.rotatable.
Steve
Le 09/09/2014 15:13, Who Cares a écrit :
> im developing an Sirius Editor for an DSL which should look very much like UML Component Diagrams.
> I have a System which contains Components, both of which can provide and require interfaces. This should be displayed as it is in UML minus the ports.
> I looked at the obeo UML designer where this is done by adding a dot style to the provided interface and then connecting this to a bordered node.
> This does not work for me, as on the components there are no two different semantic objects I could connect, I only have a provided interface, which I mapped to a bordered node. On the system itself I do have two nodes but if I try to remove the style of the bordered node it still displays the old one. Also Im wondering how I could fix both elements together so that it always looks like a UML connector.
> The easiest solution I thought of was to somehow get an image of the UML connectors to be displayed on the outside of the border, but I dont know how to do this and also the rotation of the image would need to be changed depending on the side of the system/component the connector comes out of.
> I attached an image which should help understand what I mean:
> Thanks in advance
Steve Monnier - Obeo
Need professional services for Sirius?
FUDForum. Page generated in 0.07213 seconds
