Home » Archived » BIRT » can I populate report data set by writing a Java class
can I populate report data set by writing a Java class [message #137783] Thu, 02 March 2006 01:17 Go to next message
Originally posted by: cghosh.eforceglobal.com
I am chandan. In my project I am using hibernate as a persistent layer. My
question is that can I populate report data set by writing a Java class
which in tern use HQL, without writing a SQL query in Data Set editor?
Thanks In Advance.
Chandan Ghosh
Re: can I populate report data set by writing a Java class [message #137991 is a reply to message #137783] Thu, 02 March 2006 07:31 Go to previous messageGo to next message
Originally posted by: m.n.com
The answer is yes. Check out the documentation on Scripted Dataset. And
there is quite a bit if additional info scattered throughout the newsgroup.
Chandan Ghosh wrote:
> My question is that can I populate report data set by writing a Java
> class which in tern use HQL, without writing a SQL query in Data Set
> editor?
> Thanks In Advance.
> Chandan Ghosh
Re: can I populate report data set by writing a Java class [message #141247 is a reply to message #137991] Wed, 08 March 2006 02:16 Go to previous messageGo to next message
Originally posted by: chandan.itech.yahoo.co.in
Hi Mark,
Thanks for that. I have gone through the doc. But I want to know another
thing.
That is can I pass Report Parameter through the constructor of the class
when instantiating it from BIRT.
Chandan
Re: can I populate report data set by writing a Java class [message #142006 is a reply to message #141247] Thu, 09 March 2006 08:01 Go to previous message
Originally posted by: attacus.narod.ru
Try to use a factory class. In the scripted data source you can pass a
parameter for method retreiving the data.
It works.
But I still have a starange error binding such dataset to a chart.
Othervise, with the table element there are no problems.
"Chandan" <chandan.itech@yahoo.co.in> ???????/???????? ? ???????? ?????????:
news:cf1520e4d2da2971d63f3d95cbf15a5d$1@www.eclipse.org...
> Hi Mark,
> thing.
> Chandan
Previous Topic:Ive been experimenting with oracle time formats, but nothing works
Next Topic:PDF quality
Current Time: Sat Jul 26 10:39:27 EDT 2025
Powered by FUDForum. Page generated in 0.52338 seconds
