Home » Modeling » TMF (Xtext) » [solved] Accessing types and their properties from another file (with same grammar)
[solved] Accessing types and their properties from another file (with same grammar) [message #1419928] Tue, 09 September 2014 04:59 Go to next message
I'm new to xtext and have a question. I have defined a grammar according to [an'T post link, just google xtext-and-dot-expressions] and modified it a little bit e.g. imports. My grammar now looks like this
grammar org.eclipse.xtext.example.domainmodel.Domainmodel with org.eclipse.xtext.xbase.Xbase
generate domainmodel "[interpreted as link]/example/Domainmodel"
DomainModel:
	'package' packageName=QualifiedName
	importSection=XImportSection?
	elements+=Entity*
	usages+=Usage*
Entity:
    "entity" name=ValidID "{"
        features+=Feature*
Feature:
    Attribute | Reference
Attribute:
    "attr" name=ValidID ":" type=DataType
enum DataType:
    string | int
Reference:
    "ref" name=ValidID ":" type=[Entity|QualifiedName]
Usage:
    "use" ref=DotExpression
DotExpression returns Ref:
    EntityRef ({DotExpression.ref=current}  "." tail=[Feature])*
EntityRef returns Ref:
    {EntityRef} entity=[Entity]
I have two files:
1) firstModel.dmodel
package myFirstPackage
entity myFirstEntity {
	attr value : int
2) secondModel.dmodel
package mySecondPackage
import myFirstPackage.*
entity mySecondEntity {
	attr myAttr : int
	ref myRef : myFirstEntity
use mySecondEntity.myRef
The import works, but the "dot-operation" does not. I followed christian's example, implemented the ScopeProvider and modified the bindIScopeProvider method in AbstractDomainmodelRuntimeModule.java accordingly.
Do I have to change / implement something else?
[Updated on: Thu, 11 September 2014 07:22] by Moderator
Re: Accessing types and their properties from another file (with same grammar) [message #1420226 is a reply to message #1419928] Tue, 09 September 2014 13:52 Go to previous messageGo to next message
you use xbase, is that intended? and how does your scopeprovider class look like? xbase scoping is very different from non xbase scoping
[Updated on: Tue, 09 September 2014 14:03] by Moderator
Re: Accessing types and their properties from another file (with same grammar) [message #1420236 is a reply to message #1420226] Tue, 09 September 2014 14:11 Go to previous messageGo to next message
here is what works for me
class MyDslScopeProvider extends XbaseBatchScopeProvider {
	override getScope(EObject context, EReference reference) {
		if (context instanceof DotExpression) {
			return scope_DotExpression_tail(context, reference)
		super.getScope(context, reference)
	def IScope scope_DotExpression_tail(DotExpression exp, EReference ref) {
		val head = exp.ref;
		switch (head) {
			EntityRef : Scopes::scopeFor(head.entity.features)
			DotExpression : {
				val tail = head.tail
				switch (tail) {
					Attribute : IScope::NULLSCOPE
					Reference : Scopes::scopeFor(tail.type.features)
					default: IScope::NULLSCOPE
public class MyDslRuntimeModule extends org.xtext.example.mydsl.AbstractMyDslRuntimeModule {
	public Class<? extends IBatchScopeProvider> bindIBatchScopeProvider() {
		return MyDslScopeProvider.class;
Re: Accessing types and their properties from another file (with same grammar) [message #1421443 is a reply to message #1420236] Thu, 11 September 2014 07:21 Go to previous message
Thanks Christian, it works Smile
Previous Topic:annotate a parameter in method
Next Topic:xcore, ecore, emf, xtext and maven
Current Time: Thu Jul 24 22:20:24 EDT 2025
Powered by FUDForum. Page generated in 0.05887 seconds
