Home » Eclipse Projects » Eclipse 4 » Eclipse Source Code Editor in e4 RCP
Eclipse Source Code Editor in e4 RCP [message #1416043] Thu, 04 September 2014 04:07 Go to next message
is it possible to use the source code editor known to us from Eclipse in my own e4 RCP application? It is a pure e4 application and if possible I would really like to resign with the compatibility layer.
Currently I am using StyledText for my source code editor but it is a lot of work (syntax highlighting, code completion etc) that I think could be done much more elegant by using the Eclipse source code editor.
Thx
Re: Eclipse Source Code Editor in e4 RCP [message #1417351 is a reply to message #1416043] Fri, 05 September 2014 04:34 Go to previous messageGo to next message
e3 source code editor in e4 rcp? afaik the answer is ... no.
I think the best choice atm would be the SourceViewer class from JFace. It has all the hooks for the features you listed.
Re: Eclipse Source Code Editor in e4 RCP [message #1419191 is a reply to message #1417351] Mon, 08 September 2014 04:23 Go to previous message
Right anything from eclipse.text and eclipse.jface.text can be used
inside e4 apps - even in a none-swt-env ;-) See
http://tomsondev.bestsolution.at/2014/08/11/efxclipse-1-0-new-features-styledtext-control-to-build-a-code-editor-framework/
Tom
Previous Topic:Customizing ToolBar
Next Topic:display order of menu items changed when migrated to Eclipse Luna
Current Time: Mon Jul 21 05:08:50 EDT 2025
Powered by FUDForum. Page generated in 0.03406 seconds
