Debug though co-routines [message #1417150] |
Wed, 25 June 2014 11:09  |
I'm trying to debug with koneki the code of one of the examples of Orbit MVC Framework in order to understand how to debug my web application.
github.com/keplerproject/orbit/tree/master/samples
I'm using Xavante web server which uses WSAPI to launch the "Blog" sample.
My problem is that I only can debug the xavante launcher; when WSAPI creates a co-routine I'm not able to break into the blog application.
I think the problem is due to the cration of a new LUA state, dedicated to the "blog" wb app, when the co-routine is created.
Both the solutions of local and attached debug don't work. In case of local debug my application seems to break on the first breakpoint, but I don't see it (only using print in the code) and I can't control the debug session.
I also tried with AKdebugger, but the behavior is very similar...
This is my "start.lua" code, the Xavante launcher:
require "xavante"
require "xavante.filehandler"
require "xavante.redirecthandler"
require "wsapi.xavante"
-- Define here where Xavante HTTP documents scripts are located
local webDir = "."
local simplerules = {
{ -- URI remapping example
match = "^[^%./]*/$",
with = xavante.redirecthandler,
params = {"blog.ws"}
match = {"%.ws$", "%.ws/.*$" },
with = wsapi.xavante.makeGenericHandler (webDir)
{ -- filehandler example
match = ".",
with = xavante.filehandler,
params = {baseDir = webDir}
xavante.HTTP{
server = {host = "*", port = 8080},
defaultHost = {
rules = simplerules
xavante.start()
I'm wrong in something? I'm a newbie in LUA... :d
Can anyone help me?
Thank you very much.
Luca
Re: Debug though co-routines [message #1417158 is a reply to message #1417152] |
Fri, 27 June 2014 12:27  |
Are you sure you have copied the whole log ? because after the line :
<response transaction_id="20" status="break" ...
You should have the following command, that give to eclipse the information of where the break is.
>> breakpoint_get -d 0 -i 73
<< <?xml version="1.0" encoding="UTF-8" ?>
<response transaction_id="73" command="breakpoint_get" xmlns="urn:debugger_protocol_v1"><breakpoint id="0" hit_count="1" state="enabled" filename="file:///home/maubry/LDT/standalone1.2.0.RC2/workspace/mldks/src/main.lua" hit_value="0" type="line" lineno="2" hit_condition=">="/></response>
And also you should have more commands to retrieve the context.
Before going deeper, can you just ensure you used the right debugger.lua module version ? You can find the debugger compatible with your LDT version by clicking on the link "Lua Debugger Client" in any Lua Attach Debug Configuration page.
FUDForum. Page generated in 0.30429 seconds
