Home » Archived » Koneki » Lua Modules
Lua Modules [message #1417082] Tue, 11 February 2014 21:59 Go to next message
I made a module script and then I attempted to link it with the line:
exct = require "Executable Functions"
and then I get the error message of:
Exception in thread "main" com.naef.jnlua.LuaRuntimeException: ...product-win32.win32.x86\workspace\Project\script.lua:4: module 'Executable Functions' not found:
no field package.preload['Executable Functions']
no file '.\Executable Functions.dll'
no file '.\Executable Functions51.dll'
no file 'C:\Program Files (x86)\Java\jre7\bin\Executable Functions.dll'
no file 'C:\Program Files (x86)\Java\jre7\bin\Executable Functions51.dll'
no file 'C:\Program Files (x86)\Java\jre7\bin\clibs\Executable Functions.dll'
no file 'C:\Program Files (x86)\Java\jre7\bin\clibs\Executable Functions51.dll'
no file 'C:\Program Files (x86)\Java\jre7\bin\loadall.dll'
no file 'C:\Program Files (x86)\Java\jre7\bin\clibs\loadall.dll'
at com.naef.jnlua.LuaState.lua_pcall(Native Method)
at com.naef.jnlua.LuaState.call(LuaState.java:555)
at org.eclipse.koneki.ldt.support.lua51.internal.interpreter.JNLua51Launcher.run(JNLua51Launcher.java:122)
at org.eclipse.koneki.ldt.support.lua51.internal.interpreter.JNLua51Launcher.main(JNLua51Launcher.java:137)
Help?
Re: Lua Modules [message #1417084 is a reply to message #1417082] Wed, 12 February 2014 09:37 Go to previous messageGo to next message
It's weird, your lua_path seems to not be set correctly, this looks like a bug...
Could you tell me which version of LDT did you use ? on which platform ? where is your Executable Functions script ? where is your "exct = require "Executable Functions"" code ?
Thx
Re: Lua Modules [message #1500278 is a reply to message #1417084] Fri, 05 December 2014 16:06 Go to previous message
Hi, I'm also struggling in this area. I'm guessing that there is a 32-bit/64-bit Windows conflict.
Are you on Win64? When you compiled against Lua, which did you use? I suspect that Lua for Windows is all 32-bit code.
Previous Topic:LDT debugger error
Next Topic:Autocompletion for external API
Current Time: Wed Sep 17 09:27:14 EDT 2025
Powered by FUDForum. Page generated in 0.04758 seconds
