Home » Archived » Koneki » Breakpoint not hit after attaching to Java application
Breakpoint not hit after attaching to Java application [message #1417031] Tue, 10 December 2013 11:33 Go to next message
I have ported my java code/scripts to use JNLua instead of LuaJ. JNLua respects the LUA_PATH and LUA_CPATH variables so configuration works painlessly.
Background:
(Running on Windows 64bit platform)
1) I have downloaded/installed LDT v1.0.1 in Eclipse v4.2.0
2) I have downloaded/installed JNLua v1.0.3 with Lua v5.2.1 binaries
3) I have configured my LuaRocks environment to compile Luasocket v3.0rc1-1 linking with Lua v5.2.1 libs
4) Updated PATH, LUA_PATH, and LUA_CPATH to reflect these changes and added them to the environment variables in Eclipse/LDT
5) Created a "Lua Attach to Application" target
6) Placed the "Lua Debugger Client" in the LUA_PATH path
7) Added entry point [require ("debugger")("localhost", 10000, "luaidekey")] to my lua script for debugging
I have been able to debug a dummy Lua project, so I know the environment and binaries are setup correctly.
Current Workflow:
1) Start my "Lua Attach to Application" target
2) Start my Java application
3) I can see the process attach to the Lua debugging engine
Issue:
My breakpoints are never hit when I attach and the Lua functions are called
Here is how I am calling the Lua script from Java:
import com.naef.jnlua.LuaState;
luaState.openLibs();
luaState.load(
Gdx.files.internal(scriptFileName).read(), //read() returns InputStream
Gdx.files.internal(scriptFileName).file().getName(), //getName() returns filename, "atm.lua"
"bt"); //read as binary or text
// Evaluate the chunk, thus defining the function
luaState.call(0, 0); // No arguments, no returns
Then when called later:
luaState.getGlobal("create");
luaState.pushJavaObject(entity); // Push argument #1
luaState.call(1, 0); // 1 argument, 0 return
I don't know if this is relevant, but in one of the posts this was used in the Lua script (in this case "atm.lua") for troubleshooting:
print(debug.getinfo(1).source)
For a value, I get:
atm.lua
Script Debug Log (after this run)
Event TERMINATE from org.eclipse.koneki.ldt.debug.core.internal.attach.LuaAttachDebuggingEngineRunner$1
Event CREATE from org.eclipse.koneki.ldt.debug.core.internal.attach.LuaAttachDebuggingEngineRunner$1
Event CHANGE from org.eclipse.debug.core.model.RuntimeProcess
Event CREATE from org.eclipse.debug.core.model.RuntimeProcess
Event CREATE from org.eclipse.jdt.internal.debug.core.model.JDIThread
Event CREATE from org.eclipse.jdt.internal.debug.core.model.JDIDebugTarget
Event RESUME from org.eclipse.jdt.internal.debug.core.model.JDIDebugTarget
Event CHANGE from org.eclipse.jdt.internal.debug.core.model.JDIThread
Event TERMINATE from org.eclipse.jdt.internal.debug.core.model.JDIThread
Event MODEL_SPECIFIC/5 from org.eclipse.dltk.dbgp.internal.DbgpDebugingEngine
<< <?xml version="1.0" encoding="UTF-8" ?>
<init idekey="luaidekey" parent="" fileuri="unknown:/" language="Lua" xmlns="urn:debugger_protocol_v1" session="1386691895_thread: 0077E000" protocol_version="1.0" thread="thread: 0077E000" appid="Lua DBGp"/>
>> feature_set -n max_children -i 285 -v 32
<response xmlns="urn:debugger_protocol_v1" transaction_id="285" success="1" command="feature_set" feature="max_children"/>
>> feature_set -n max_depth -i 286 -v 2
<response xmlns="urn:debugger_protocol_v1" transaction_id="286" success="1" command="feature_set" feature="max_depth"/>
>> feature_set -n max_data -i 287 -v 8192
<response xmlns="urn:debugger_protocol_v1" transaction_id="287" success="1" command="feature_set" feature="max_data"/>
>> feature_get -n stdin -i 288
<response xmlns="urn:debugger_protocol_v1" supported="0" transaction_id="288" command="feature_get" feature_name="stdin"><![CDATA[false]]></response>
>> feature_set -n notify_ok -i 289 -v 1
<response xmlns="urn:debugger_protocol_v1" transaction_id="289" success="0" command="feature_set" feature="notify_ok"/>
>> stdout -c 2 -i 290
<response transaction_id="290" success="1" command="stdout" xmlns="urn:debugger_protocol_v1"/>
>> stderr -c 2 -i 291
<response transaction_id="291" success="1" command="stderr" xmlns="urn:debugger_protocol_v1"/>
>> breakpoint_set -r 0 -t line -s enabled -n 15 -i 292 -f file:///F:/Users/phoey/phoey_phoeyPC/workspace/cyberpunkgame-android/assets/data/scripts/atm.lua
<response state="enabled" xmlns="urn:debugger_protocol_v1" id="0" transaction_id="292" command="breakpoint_set"/>
>> breakpoint_set -r 0 -t line -s enabled -n 34 -i 293 -f file:///F:/Users/phoey/phoey_phoeyPC/workspace/cyberpunkgame-android/assets/data/scripts/atm.lua
<response state="enabled" xmlns="urn:debugger_protocol_v1" id="1" transaction_id="293" command="breakpoint_set"/>
>> breakpoint_set -r 0 -t line -s enabled -n 24 -i 294 -f file:///F:/Users/phoey/phoey_phoeyPC/workspace/cyberpunkgame-android/assets/data/scripts/atm.lua
<response state="enabled" xmlns="urn:debugger_protocol_v1" id="2" transaction_id="294" command="breakpoint_set"/>
>> breakpoint_set -r 0 -t line -s enabled -n 12 -i 295 -f file:///F:/Users/phoey/phoey_phoeyPC/workspace/cyberpunkgame-android/assets/data/scripts/atm.lua
<response state="enabled" xmlns="urn:debugger_protocol_v1" id="3" transaction_id="295" command="breakpoint_set"/>
>> run -i 296
Event CREATE from org.eclipse.dltk.internal.debug.core.model.ScriptThread
Event MODEL_SPECIFIC/4 from org.eclipse.dltk.internal.debug.core.model.ScriptThread
Event RESUME from org.eclipse.dltk.internal.debug.core.model.ScriptThread
Event CHANGE from org.eclipse.dltk.internal.debug.core.model.ScriptThread
Event MODEL_SPECIFIC/2 from org.eclipse.koneki.ldt.debug.core.internal.attach.LuaAttachDebuggingEngineRunner$1
<stream xmlns="urn:debugger_protocol_v1" type="stdout"><![CDATA[IyMjIyMjIyMjIyMjIyMjI0RFQlVHR0VSIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMj
IyMjIyMjIyMjIyMjIyMjIyMjIyMNCg==
]]></stream>
<stream xmlns="urn:debugger_protocol_v1" type="stdout"><![CDATA[YXRtLmx1YQ0K
]]></stream>
]]></stream>
Question(s)
1) Am I doing anything obviously wrong as the reason for why I am not hitting the breakpoints when the function is called?
2) What are areas that I can troubleshoot for these types of issues?
Thanks.
Re: Breakpoint not hit after attaching to Java application [message #1417032 is a reply to message #1417031] Wed, 11 December 2013 06:40 Go to previous messageGo to next message
Hi Patrick,
You're right, currently the debugger is not able to manage "dynamic code". (but not sure it's your case)
By default, to identify lua file, debugger client and server use the absolute path of the file.
(This could change if you not use the default https://wiki.eclipse.org/Koneki/LDT/Developer_Area/User_Guides/User_Guide_1.0#Source_Mapping : local resolution => see launch configuration Lua Attach to Application)
To retrieve the absolute path of a lua file, the "Lua Debugger Client", use debug.getinfo(1).source.
If it is a absolute path, there nothing to do.
If this is a relative path, we try to retreive the absolute path by concatenate working directory + relative path from debug.getinfo(1).source
A regular problem could be that working directory is not guess correctly so you could https://wiki.eclipse.org/Koneki/LDT/Developer_Area/User_Guides/User_Guide_1.0#Attach_session by using the DBGP_WORKINGDIR environment variable or passing it as parameters
Maybe the problem could be also solved by using absolute path when you load the file :
luaState.load(
Gdx.files.internal(scriptFileName).file().getAbsolutePath(), => you could path the absolute path here maybe this will works. (not sure getAbsolutePath is exactly the good method :p)
Re: Breakpoint not hit after attaching to Java application [message #1417034 is a reply to message #1417032] Wed, 11 December 2013 11:47 Go to previous message
Hello Simon,
Thank you for the reply and recommendations.
As for my environment, I am using the default source mapping, local resolution.
I set the DBGP_WORKINGDIR to my Lua script project directory, and just for testing, I passed in the entire absolute path. The breakpoint was still not hit.
I also (just for testing) passed in the name of the file as the absolute path in the LuaState.load() call in my Java code. "debug.getinfo(1).source" returned the full absolute path to the script file as expected, but the breakpoint still was not hit.
I troubleshooted a little further and put print statements in the debugger.lua file on all the variables used to initialize the debugger. All the values printed out correct, including "workingdirectory."
Unfortunately, with the working directory set correct, the debugger *should* have the information necessary in order to evaluate the path where the atm.lua script is.
Out of desperation at this point, I looked at alternative debug environments and found ZeroBrane's Studio Lua Debugger. I installed and set a breakpoint, and without much configuration was able to debug my script. I don't know if this has to do with dynamic code, but if it does, I hope dynamic code support in on the roadmap for LDT.
Anyways, thank you again.
Previous Topic:Sample code used in LDT to generate AST
Next Topic:Proper method to debug Lua script from Luaj project
Current Time: Wed Jul 23 23:29:50 EDT 2025
Powered by FUDForum. Page generated in 0.24814 seconds
