Can LDT debug Lua in a C app? [message #1416864] |
Wed, 24 April 2013 14:25  |
My project is a Windows console app written in c with Lua 5.2 embedded. I need a way to debug the Lua code. I have tried to Debug my project in LDT Eclipse, but it only works for a Lua Project, mine is c/c++ project.
Does LDT support a way to debug my Lua code?
Re: Can LDT debug Lua in a C app? [message #1416870 is a reply to message #1416869] |
Mon, 29 April 2013 07:41  |
You talk about 'interpreter' and 'Launch script'? Your comment is confusing but I suppose you tried the second solution (so you downloaded the 1.0.0M1 version).
Did you test the first one ?
If you want to use the second solution, I will try to make it clearer :
When you use a "standard" Lua Interpreter (Lua 5.1, wxLua, LuaJIT ...), you could pass the file you want to be interpreted by the VM.
If I understand in your case, your C application (which will be considered by LDT as an interpreter) can not take a Script file in parameters. So in this case, you must fake the UI and Select any file.
(I agree this is not really userfriendly)
When you registered your interpreter, you need to check/uncheck options in function of your interpreter capabilities. (http://wiki.eclipse.org/Koneki/LDT/Developer_Area/User_Guides/User_Guide_1.0#Managing_Interpreters)
You say you have no external script, but I suppose your C application load some lua files. Files which are present in your project. Files on which you will set breakpoints. If not, please can you explain me where is your Lua code ?
Now to debug your application, the lua debugger client should be launched. Generally this is done automatically by LDT thx to the -e option but if your application don't support this convention you must launch the debugger on your own.
So choose the lua file which is loading in first and add this line of code at begin : (http://wiki.eclipse.org/Koneki/LDT/Developer_Area/User_Guides/User_Guide_1.0#Lo[code)
if os.getenv('DEBUG_MODE') then require "debugger"() end[/code]
Do not forget your need luasocket to allow the debugger client to connect to the debugger Server integrated in LDT.
FUDForum. Page generated in 0.77956 seconds
