Home » Archived » Koneki » Problem Starting Koneki with DM-Server 3.6
Problem Starting Koneki with DM-Server 3.6 [message #1416533] Tue, 24 July 2012 10:59 Go to next message
Hello. I'm kinda new to this world, i'm trying to setup the funambol dm-server 3.6 and Koneki. I've followed this guide to install and setup both Koneki and DM-Server:
http://wiki.eclipse.org/Koneki/Simulators/OMA-DM/User_Guide
I'm on opensuse 11.4, every Ambient variable are set to the right place, i can install the jboss5 and set up the data base without any problem.
The DM-Server starts up just fine (at least i guess), after that i create a new ID to use and try to connect via Koneki and then i get the following exception:
15:51:17,058 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,086 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,183 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
15:51:17,619 ERROR [STDERR] org.jibx.runtime.JiBXException: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
15:51:17,620 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalElement(UnmarshallingContext.java:2565)
15:51:17,620 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalDocument(UnmarshallingContext.java:2736)
15:51:17,620 ERROR [STDERR] at com.funambol.server.engine.SyncAdapter.processMessage(SyncAdapter.java:287)
15:51:17,620 ERROR [STDERR] at com.funambol.server.syncbean.SyncBean.processMessage(SyncBean.java:228)
15:51:17,620 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
15:51:17,620 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
15:51:17,620 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
15:51:17,620 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
15:51:17,621 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
15:51:17,621 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
15:51:17,621 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
15:51:17,621 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:597)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
15:51:17,621 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_1852690398.invoke(InvocationContextInterceptor_z_fillMethod_1852690398.java)
15:51:17,621 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
15:51:17,622 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_1852690398.invoke(InvocationContextInterceptor_z_setup_1852690398.java)
15:51:17,622 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.entity.ExtendedPersistenceContextPropagationInterceptor.invoke(ExtendedPersistenceContextPropagationInterceptor.java:60)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
15:51:17,622 ERROR [STDERR] at org.jboss.ejb3.stateful.StatefulInstanceInterceptor.invoke(StatefulInstanceInterceptor.java:81)
15:51:17,622 ERROR [STDERR] at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
15:51:17,622 ERROR [STDERR] at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
15:51:17,623 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
15:51:17,623 ERROR [STDERR] at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
15:51:17,623 ERROR [STDERR] at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:176)
15:51:17,623 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:216)
15:51:17,624 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
15:51:17,624 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
15:51:17,624 ERROR [STDERR] at $Proxy266.processMessage(Unknown Source)
15:51:17,624 ERROR [STDERR] at com.funambol.transport.http.server.LocalEJBSyncHolder.processMessage(LocalEJBSyncHolder.java:88)
15:51:17,624 ERROR [STDERR] at com.funambol.transport.http.server.Sync4jServlet.doPost(Sync4jServlet.java:250)
15:51:17,624 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
15:51:17,624 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
15:51:17,624 ERROR [STDERR] at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
15:51:17,624 ERROR [STDERR] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
15:51:17,624 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
15:51:17,625 ERROR [STDERR] at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
15:51:17,625 ERROR [STDERR] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
15:51:17,625 ERROR [STDERR] at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
15:51:17,625 ERROR [STDERR] at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
15:51:17,625 ERROR [STDERR] at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
15:51:17,625 ERROR [STDERR] at java.lang.Thread.run(Thread.java:662)
15:51:17,625 FATAL [SyncAdapter] Error unmarshalling message: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
15:51:17,647 ERROR [[SyncServerServlet]] Servlet.service() for servlet SyncServerServlet threw exception
I'm Doing something wrong? i've look to the guide number of times and i don't understand ehat i may be doing wrong...
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416535 is a reply to message #1416533] Tue, 24 July 2012 12:09 Go to previous messageGo to next message
Hi Andre,
Could you post the XML messages that the simulator is sending and that are causing trouble. You can get them from the Dashboard/Message view tab.
Thanks!
Benjamin.
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416536 is a reply to message #1416535] Tue, 24 July 2012 12:50 Go to previous messageGo to next message
Benjamin Cabe wrote on Tue, 24 July 2012 12:09
> Hi Andre,
> Thanks!
> Benjamin.
First of all thank you for your answer, and of course. The message is the follow:
<SyncML xmlns="SYNCML:SYNCML1.2">
<SyncHdr>
<VerDTD>1.2</VerDTD>
<VerProto>DM/1.2</VerProto>
<SessionID>1</SessionID>
<MsgID>1</MsgID>
<Target>
<LocURI>h**p://localhost:8080/funambol/dm</LocURI>
</Target>
<Source>
<LocURI>FREE:12345</LocURI>
</Source>
<Cred>
<Meta>
<Format xmlns="syncml:metinf">b64</Format>
<Type xmlns="syncml:metinf">syncml:auth-basic</Type>
</Meta>
<Data>ZnVuYW1ib2w6ZnVuYW1ib2w=</Data>
</Cred>
</SyncHdr>
<SyncBody>
<Alert>
<CmdID>1</CmdID>
<Data>1201</Data>
</Alert>
<Replace>
<CmdID>2</CmdID>
<Meta>
<Format xmlns="syncml:metinf">chr</Format>
<Type xmlns="syncml:metinf">text/plain</Type>
</Meta>
<Item>
<Source>
<LocURI>./DevInfo/DevId</LocURI>
</Source>
<Data>FREE:12345</Data>
</Item>
<Item>
<Source>
<LocURI>./DevInfo/DwV</LocURI>
</Source>
<Data/>
</Item>
<Item>
<Source>
<LocURI>./DevInfo/Man</LocURI>
</Source>
<Data>Nokia</Data>
</Item>
<Item>
<Source>
<LocURI>./DevInfo/Mod</LocURI>
</Source>
<Data>S534</Data>
</Item>
<Item>
<Source>
<LocURI>./DevInfo/Lang</LocURI>
</Source>
<Data>PT</Data>
</Item>
</Replace>
<Final/>
</SyncBody>
</SyncML>
I haven't touch in the eclipse code so far. So i guess this is the standard message for the setup phase.
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416559 is a reply to message #1416536] Mon, 30 July 2012 05:11 Go to previous messageGo to next message
Anyone have any idea why this is happen? i've tryed almost everything i could remember, clean install the DM-Server, reinstall Koneki, check the libs on server side, and i'm getting no where..
If someone could help me it would be awesome.
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416564 is a reply to message #1416559] Wed, 01 August 2012 05:11 Go to previous messageGo to next message
The generated XML is fine for me. I suppose the problem is funambol.
Yio uare sure your funambol path is correct ? 8080:/funambol/dm is for OMADM ?
Please can you make a wireshark capture of the client/server communication ? The idea is to check in the HTTP content-type is correct.
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416612 is a reply to message #1416533] Mon, 27 August 2012 17:08 Go to previous messageGo to next message
I have exactly the same issue as Andre. Installation of JBoss, Koneki and Funambol worked fine, I can access the Funambol and JBoss web interface, the devices I create get stored in the database.
But when I want to connect with Koneki, the following happens:
Koneki shows an alert with "HTTP/1.1 500 Internal Server Error" and I get the same error log as Andre:
22:54:36,133 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,137 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,171 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,172 WARN [InterceptorsFactory] EJBTHREE-1246: Do not use InterceptorsFactory with a ManagedObjectAdvisor, InterceptorRegistry should be used via the bean container
22:54:36,389 ERROR [STDERR] org.jibx.runtime.JiBXException: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
22:54:36,390 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalElement(UnmarshallingContext.java:2565)
22:54:36,390 ERROR [STDERR] at org.jibx.runtime.impl.UnmarshallingContext.unmarshalDocument(UnmarshallingContext.java:2736)
22:54:36,390 ERROR [STDERR] at com.funambol.server.engine.SyncAdapter.processMessage(SyncAdapter.java:287)
22:54:36,391 ERROR [STDERR] at com.funambol.server.syncbean.SyncBean.processMessage(SyncBean.java:228)
22:54:36,391 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
22:54:36,391 ERROR [STDERR] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
22:54:36,391 ERROR [STDERR] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
22:54:36,391 ERROR [STDERR] at java.lang.reflect.Method.invoke(Method.java:616)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeTarget(MethodInvocation.java:122)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:111)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.EJBContainerInvocationWrapper.invokeNext(EJBContainerInvocationWrapper.java:69)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.invoke(InterceptorSequencer.java:73)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InterceptorSequencer.aroundInvoke(InterceptorSequencer.java:59)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.advice.PerJoinpointAdvice.invoke(PerJoinpointAdvice.java:174)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.fillMethod(InvocationContextInterceptor.java:72)
22:54:36,391 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_fillMethod_10922545.invoke(InvocationContextInterceptor_z_fillMethod_10922545.java)
22:54:36,391 ERROR [STDERR] at org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor.setup(InvocationContextInterceptor.java:88)
22:54:36,398 ERROR [STDERR] at org.jboss.aop.advice.org.jboss.ejb3.interceptors.aop.InvocationContextInterceptor_z_setup_10922545.invoke(InvocationContextInterceptor_z_setup_10922545.java)
22:54:36,398 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:62)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.entity.ExtendedPersistenceContextPropagationInterceptor.invoke(ExtendedPersistenceContextPropagationInterceptor.java:60)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.entity.TransactionScopedEntityManagerInterceptor.invoke(TransactionScopedEntityManagerInterceptor.java:56)
22:54:36,398 ERROR [STDERR] at org.jboss.ejb3.AllowedOperationsInterceptor.invoke(AllowedOperationsInterceptor.java:47)
22:54:36,399 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.tx.NullInterceptor.invoke(NullInterceptor.java:42)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.stateful.StatefulInstanceInterceptor.invoke(StatefulInstanceInterceptor.java:81)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxPolicy.invokeInOurTx(TxPolicy.java:79)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxInterceptor$Required.invoke(TxInterceptor.java:190)
22:54:36,399 ERROR [STDERR] at org.jboss.aspects.tx.TxPropagationInterceptor.invoke(TxPropagationInterceptor.java:76)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.security.Ejb3AuthenticationInterceptorv2.invoke(Ejb3AuthenticationInterceptorv2.java:186)
22:54:36,399 ERROR [STDERR] at org.jboss.ejb3.ENCPropagationInterceptor.invoke(ENCPropagationInterceptor.java:41)
22:54:36,405 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,405 ERROR [STDERR] at org.jboss.ejb3.BlockContainerShutdownInterceptor.invoke(BlockContainerShutdownInterceptor.java:67)
22:54:36,406 ERROR [STDERR] at org.jboss.aspects.currentinvocation.CurrentInvocationInterceptor.invoke(CurrentInvocationInterceptor.java:67)
22:54:36,406 ERROR [STDERR] at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:176)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.session.SessionSpecContainer.invoke(SessionSpecContainer.java:216)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:207)
22:54:36,406 ERROR [STDERR] at org.jboss.ejb3.proxy.impl.handler.session.SessionProxyInvocationHandlerBase.invoke(SessionProxyInvocationHandlerBase.java:164)
22:54:36,406 ERROR [STDERR] at $Proxy266.processMessage(Unknown Source)
22:54:36,406 ERROR [STDERR] at com.funambol.transport.http.server.LocalEJBSyncHolder.processMessage(LocalEJBSyncHolder.java:88)
22:54:36,406 ERROR [STDERR] at com.funambol.transport.http.server.Sync4jServlet.doPost(Sync4jServlet.java:250)
22:54:36,406 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
22:54:36,406 ERROR [STDERR] at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
22:54:36,406 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
22:54:36,406 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
22:54:36,406 ERROR [STDERR] at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
22:54:36,407 ERROR [STDERR] at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
22:54:36,407 ERROR [STDERR] at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
22:54:36,407 ERROR [STDERR] at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
22:54:36,407 ERROR [STDERR] at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
22:54:36,407 ERROR [STDERR] at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
22:54:36,408 ERROR [STDERR] at java.lang.Thread.run(Thread.java:636)
22:54:36,408 FATAL [SyncAdapter] Error unmarshalling message: No unmarshaller for element "{SYNCML:SYNCML1.2}SyncML" (line 1, col 71)
22:54:36,425 ERROR [[SyncServerServlet]] Servlet.service() for servlet SyncServerServlet threw exception
Any ideas? Are there any Funambol servers out there which are open to use? This way I could at least check if my Koneki is working correctly.
Thanks in advance,
Brandon
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416627 is a reply to message #1416612] Wed, 29 August 2012 11:05 Go to previous messageGo to next message
Guys, any luck refering to http://www.eclipse.org/forums/index.php/mv/msg/369316/901263/#msg_901263?
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416637 is a reply to message #1416533] Mon, 03 September 2012 12:53 Go to previous messageGo to next message
I thought of that as well, but i kinda discard that option because i'm using a regular version: java version "1.6.0_24", JDK version, and i think by the time the test was made in the same version of java. Or it would require me to have java 1.7?
I been thinking on that, why i'm keep receiving the "internal Error". I'll try on the ubuntu virtual machine and if i can there i'll check for diferences..
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416638 is a reply to message #1416637] Tue, 04 September 2012 08:51 Go to previous messageGo to next message
Still no Luck. I've tried on Ubuntu, tried to change the Java to sun 1.6 jdk. Do i need to have a special user or special configuration on the postgresql engine and/or funambol database?
Right now i'm starting to question everything i can think of...
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416639 is a reply to message #1416638] Tue, 04 September 2012 12:20 Go to previous messageGo to next message
Just another question. I'm trying to find where the Unmarshal is registered for SyncML1.2, on the server side, maybe i'm getting something wrongly done and this is never registered and thus can't be found during runtime?
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416640 is a reply to message #1416639] Tue, 04 September 2012 12:35 Go to previous messageGo to next message
Unfortunately I don't use the Funambol server on a daily basis... I hope Brandon can help you here... It seems that for him switching from Debian to Ubuntu did the trick ; maybe he can provide you with more accurate information on what needs to be put on the Ubuntu box... :?
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416643 is a reply to message #1416533] Wed, 05 September 2012 06:47 Go to previous messageGo to next message
Hello guys,
here all the information how I got it to work:
Software:
- Ubuntu: ubuntu-12.04.1-desktop-i386 (32 Bit) via ht*p://www.ubuntu.com/download/desktop/thank-you?distro=desktop&release=lts&bits=32
- VirtualBox 4.1.18 with NAT and port forwarding for 8080 (though this shouldn't be necessary until you use Eclipse in your host OS and Funambol on your guest OS)
- jBoss: jboss-5.1.0.GA-jdk6 via ht*p://sourceforge.net/projects/jboss/files/JBoss/JBoss-5.1.0.GA/jboss-5.1.0.GA-jdk6.zip/download (Personally I think maybe this is what causes the error, maybe you used jBoss without the JDK6?)
- PostgreSQL 9.1.5 via apt-get
- postgresql-9.1-902.jdbc3 via ht*p://jdbc.postgresql.org/download/postgresql-9.1-902.jdbc3.jar
- Java OpenJDK 1.6.0_24 via apt-get (so you don't need the Sun Java)
- Eclipse 3.7.2-1 (Indigo) via apt-get
- Koneki simulator 0.8 via Eclipse package manager and ht*p://download.eclipse.org/koneki/releases as repository
- Funambol from a thread in this forum
File system looks like this:
/home/brandon/funambol/Funambol/dm-server/<funambol content>
/home/brandon/funambol/Funambol/jboss-5.1.0.GA/<jboss content>
/home/brandon/funambol/Funambol/postgresql-9.1-902.jdbc3.jar
I have a PostgreSQL-user named funambol with password funambol who has full rights on the database called funambol.
You can check it by switching to the "postgres" linux user (with "sudo su postgres" in Ubuntu since I actually never set a password for this user...)
Then you start the command line tool with "psql" and type "\l". You should see a database named funambol with encoding UTF8 and access privileges for a user called funambol.
If there is something wrong I can provide you the commands you need to enter to create a user.
Path variables in /home/brandon/.profile:
export J2EE_HOME="/home/brandon/funambol/Funambol/jboss-5.1.0.GA/"
export JAVA_HOME="/usr/lib/jvm/java-6-openjdk-i386/"
export JBOSS_CLASSPATH="/home/brandon/funambol/Funambol/postgresql-9.1-902.jdbc3.jar"
You can test if they work with "echo $J2EE_HOME" in a shell. Rebuilding the .profile-file is done with "source .profile".
My install.properties file for Funambol looks like this:
# Funambol Device Management Server
# Installation properties
# The server URI
server-name=ht*p://localhost:8080/funambol/dm
# The context path to use to access DM Server
context-path=/funambol
# The DBMS name. One of:
# - ansisql99
# - hypersonic
# - mysql
# - oracle
# - postgresql
# - sqlserver
# - sybase
# - db2
dbms=postgresql
# JDBC settings:
# classpath: the classpath of the JDBC driver
# url: the url to access the database with the choosen JDBC driver
# user: the db user
# password: the user's password
# Hypersonic
# jdbc.classpath=<somepath>/hsqldb.jar
# jdbc.driver=org.hsqldb.jdbcDriver
# jdbc.url=jdbc:hsqldb:hsql://<hostname>:1476
# jdbc.user=sa
# jdbc.password=
# PostgreSQL
# jdbc.classpath=<somepath>/postgresql.jar
# jdbc.driver=org.postgresql.Driver
# jdbc.url=jdbc:postgresql://<hostname>/funambol
# jdbc.user=funambol
# jdbc.password=funambol
# MySQL
# jdbc.classpath=<somepath>/mysql-connector-java-3.0.8-stable-bin.jar
# jdbc.driver=com.mysql.jdbc.Driver
# jdbc.url=jdbc:mysql://[hostname][,failoverhost...][:port]/[dbname][?param1=value1][&param2=value2]
# ORACLE
# jdbc.classpath=<somepath>/ojdbc14.jar
# jdbc.driver=oracle.jdbc.driver.OracleDriver
# jdbc.url=jdbc:oracle:thin:[@hostname][:<port1521>][:sid]
# Sybase
# jdbc.classpath=
# jdbc.driver=com.sybase.jdbc.SybDriver
# jdbc.url=jdbc:sybase:Tds:host:port[/database]?property=value[?property=value]
# SQL Server
# jdbc.classpath=
# jdbc.driver=com.microsoft.jdbc.sqlserver.SQLServerDriver
# jdbc.url=jdbc:microsoft:sqlserver://localhost:1433;SelectMethod=Cursor
# DB2
# jdbc.classpath=<somepath>/db2jcc_license_x.jar;<somepath>/db2jcc.jar
# jdbc.driver=com.ibm.db2.jcc.DB2Driver
# jdbc.url=jdbc:db2://[hostname][:<port50000>]/[dbname]
# ORACLE
# THIS ONE BELOW !!!
jdbc.classpath=/home/brandon/funambol/Funambol/postgresql-9.1-902.jdbc3.jar
# THIS ONE ABOVE !!!
jdbc.url=jdbc:postgresql://localhost/funambol
jdbc.user=funambol
Be sure that the line discretely marked is correct in your file.
After starting the Funambol server and creating a new device called "device1" here ht*p://localhost:8080/dmdemo/ and adding a command like "get device details", connect with Koneki:
Server URI: ht*p://localhost:8080/funambol/dm
Server login: funambol
Server password: funambol
Device ID: device1 (remember to remove the "FREE:" or anything else in front of it after you used the creation guide).
That's it. I hope I didn't forget any information. If I did, feel free to ask, I'll try to look into this thread at least every day.
And sorry for masking all the links to ht*p but the forum doesn't trust me.
Brandon
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416644 is a reply to message #1416643] Wed, 05 September 2012 07:33 Go to previous messageGo to next message
Wow, great work Brandon thanks so much!
I think that pieces of this should probably be used to update the documentation on the wiki. We should try to do that when Andre will have figured out what was wrong on his installation.
BTW Brandon you can subscribe to the topic to get e-mail notifications when a new post arrives!
Benjamin.
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416645 is a reply to message #1416644] Wed, 05 September 2012 12:30 Go to previous messageGo to next message
Hello, and thank you Brandon for your excellent post explaining every step of the way. But i'm out of luck for shore :( I tried exactly as u wrote, step by step, using the same components in the same version. The OS is exactly the same, the virtual machine is VirtualBox 4.1.20 (can't be that), the java version is also the same installed trough apt-get aswell. The eclipse was installed via apt-get as well... Alcomponents are inside the virtual machine, altho the host syste is on 64bits, but the vm i insalled is the 32bit one. Everything "by the book" and still got that error message saying it has no unmarshaller for element {SYNCML:SYNCML1.2}SYNCML :S.
I'm so frustrated right now..
I don't understand much yet about unmarshaller elements, but i think they have to be in one specific document, is it possible that need document is missing from my installation by any reason?
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416646 is a reply to message #1416533] Wed, 05 September 2012 14:34 Go to previous messageGo to next message
Hey,
I'm actually out of ideas now.
I uploaded my dm-server folder, my .profile file and an overview over all installed packages here:
h*tp://netload.in/datei934otcRlvI/dm-server.tar.bz2.htm
Unzip it with the command "tar xfvj dm-server.tar.bz2" if there is no GUI tool for that. You can create a list of all installed packages with "dpkg -l > packages.txt".
Remember to edit the .profile file and the file dm-server/install.properties. Maybe you should just copy all the files to the folder /home/USERNAME/funambol/Funambol.
So this folder should contain:
- the folder "dm-server" copied from my archieve
- the folder "jboss-5.1.0.GA", maybe you should download it again (remember, the -SDK version)
- the file "postgresql-9.1.902.jdbc3.jar"
Then you just have to edit the .profile and the dm-server/install.properties the way that you overwrite the word "USER" with your username. And maybe doublecheck the database account.
Oh and maybe you should check the rights on all the files and folders. If you don't care about the rights, I think a "chmod -R 777" on the folder funambol would definetely be worth a try!
When you did all of this and it won't work, I really have no clue how to help. If you have any ideas what you would like to check, let me know. My last idea would be a complete image of my VM, but this would be several gigabyte and with my internet connection it would take forever to upload.
Best of luck,
Brandon
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416834 is a reply to message #1416533] Sat, 30 March 2013 19:32 Go to previous messageGo to next message
The solution of "org.jibx.runtime.JiBXException" is simple.
You have to JIBX compile after finishing java file compile.
I have compiled Funambol DM Server ver 3.7 which I downloaded in "h*tp://en.sourceforge.jp/projects/okamoto/"
Okamoto Funambol DM Server 3.7 is tomcat server based and built by "ant".
If you look into "build.xml", you will find jibx compile task.
Good luck.
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416933 is a reply to message #1416834] Fri, 05 July 2013 08:40 Go to previous messageGo to next message
We experience the same problem here as the others.
dm-server looks good, but the when connecting /funambol/dm we have the same error message.
The system is Ubuntu 13.04, I have tried Funambol versions:
3.5.1, bundled with hsql, java and jboss 3.2, no distribution-dependent component at all.
3.6 with jboss 4.1, and Sun Java 1.7
3.7 with tomcat7 and openjdk7
the result is the same for all... /dmdemo works fine, but /funambol/dm drops the "unsupported method" message.
Anyway, what should happen if I just open a browser and point to ht2p://localhost:8080/funambol/dm ?? 'cos now the error happens, but the guys developing the client reports the same error when connecting with the sample koneki client as well!
Re: Problem Starting Koneki with DM-Server 3.6 [message #1416945 is a reply to message #1416933] Tue, 09 July 2013 12:56 Go to previous message
H Brandon F,
I know this is a long shot, but by any chance have you gotten OTA to work with Koneki? I am trying to get it working right now, and am stuck. Any help would be much appreciated.
Thanks!
Previous Topic:How to do FUMO?
Next Topic:LDT - Execution Environment. Help!
Current Time: Wed Jul 23 20:29:23 EDT 2025
Powered by FUDForum. Page generated in 0.09784 seconds
