Home » Modeling » TMF (Xtext) » Errors while running Xtext Junit from command line
Errors while running Xtext Junit from command line [message #1413361] Thu, 28 August 2014 07:03 Go to next message
I have written a DSL and added Junit test case using Xtext Junit by injecting AdInjectorProvider .
When I run from eclipse I am able to run the Test case , but if I run from command line by adding all the required jars in classpath, it gives below error:
 1) No implementation for javax.inject.Provider<org.eclipse.emf.ecore.resource.ResourceSet> was bound.
     [java]   while locating javax.inject.Provider<org.eclipse.emf.ecore.resource.ResourceSet>
     [java]     for field at com.mydsl.TestMyDsl.resourceSet(TestMyDsl.java:48)
     [java]   while locating com.mydsl.TestMyDsl
Any Help is really Appreciated.
Cheers
Kunal
[Updated on: Thu, 28 August 2014 07:05] by Moderator
Re: Errors while running Xtext Junit from command line [message #1414272 is a reply to message #1413361] Sat, 30 August 2014 16:57 Go to previous messageGo to next message
On 28/08/2014 13:03, Kunal Khaware wrote:
> below error:
> bound.
> [java] for field at
> com.mydsl.TestAdXtext.resourceSet(TestMyDsl.java:48)
> Cheers
> Kunal
how do you run it from the command line?
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Errors while running Xtext Junit from command line [message #1414709 is a reply to message #1414272] Mon, 01 September 2014 01:51 Go to previous messageGo to next message
I have created a TestRunner Class to run all Xtext Junit Class like below:
		Result result = JUnitCore.runClasses(MyDslTestSuite.class);
		int totalTestCasesCount = result.getRunCount();
		int failureCount = result.getFailureCount();
		System.out.println("-------------------------------------------------------------");
		System.out.println("Total Test Cases Executed = "+totalTestCasesCount);
		System.out.println("Total Test Cases Passed = "+(totalTestCasesCount - failureCount));
		System.out.println("Total Test Cases Failed = "+failureCount);
		System.out.println("Total Time taken to execute all test cases = "+result.getRunTime() +" milliseconds");
	    for (Failure failure : result.getFailures()) {
	      System.out.println(failure.toString());
While MyDslTestSuite class contains code to invoke all Junit class.Code looks like below :
import org.junit.runner.RunWith;
import org.junit.runners.Suite;
@RunWith(Suite.class)
@Suite.SuiteClasses(
			TestMyDslXtext.class
public class MyDslTestSuite {
After this, I have added all xtext libraries in classpath and ran TestRunner class from command line using command
java TestRunner
But after I see the the exception that I added in previous post.
Cheers
Kunal
Re: Errors while running Xtext Junit from command line [message #1415989 is a reply to message #1414709] Thu, 04 September 2014 01:30 Go to previous messageGo to next message
Hi Lorenzo Bettini,
Any Luck for the above please !!!
Re: Errors while running Xtext Junit from command line [message #1416005 is a reply to message #1415989] Thu, 04 September 2014 02:20 Go to previous messageGo to next message
This Post seems to be continuation of https://www.eclipse.org/forums/index.php/m/1416000/#msg_1416000
Re: Errors while running Xtext Junit from command line [message #1416014 is a reply to message #1415989] Thu, 04 September 2014 02:49 Go to previous messageGo to next message
On 04/09/2014 07:30, Kunal Khaware wrote:
> Hi Lorenzo Bettini,
sorry but I don't know: to run tests from the command line I use build
tools like maven/tycho or buckminster
Lorenzo
Xtext Book:
Re: Errors while running Xtext Junit from command line [message #1416100 is a reply to message #1416014] Thu, 04 September 2014 06:07 Go to previous message
Hi Lorenzo,
I have used ant build script and inside that I am using Junit target to run xtext junit test cases.
Cheers
Kunal
Previous Topic:Headless Xcore generation with edit plug-in
Next Topic:My DSL plugin install fails
Current Time: Wed Jul 23 18:31:47 EDT 2025
Powered by FUDForum. Page generated in 0.04112 seconds
