Sirius doesn't work with Xtext [message #1415842] |
Wed, 03 September 2014 16:03  |
Hi all,
I have an existing Xtext project that I want to integrate with Sirius.
I have read a lot in this forum and some blogs, but none of the proposed solutions worked for me. When I disable my DSL plugin, Sirius works perfectly and it is possible to create diagrams according to the viewpoint I specified.
I double checked my Eclipse, it has the org.eclipse.sirius.common.xtext jar, which contains the classes that were supposed to fix my issue.
Is there something else I forgot doing?
Att
Re: Sirius doesn't work with Xtext [message #1417538 is a reply to message #1416032] |
Fri, 05 September 2014 13:13  |
Hi Alex,
Sure.
I have an existing Xtext project, it works perfectly. I discovered Sirius a few weeks ago, and I am trying to create a set of viewpoints for the textual descriptions I create with my DSL.
Its just the basics, I am pretty sure I am missing something.
What I did until now:
- Create a .odesign file with a single viewpoint, for testing purposes. Based on my existing ecore model.
- Defined a few nodes and relationships in the odesign file.
- Trying to run it.
Aparently, the problem is that Sirius can't read the model when it is described with Xtext (since when I disable the xtext plugin and create a XMI file based on the ecore, it works), what is supposed to be fixed with that org.eclipse.sirius.common.xtext plugin. How can I be sure this plugin is installed and beeing used? My Eclipse folder has it, but I really dont know if it is activated.
Resuming, the issue is that Sirius isn't understanding my models when described using Xtext. What do I miss?
[Updated on: Fri, 05 September 2014 13:15] by Moderator
FUDForum. Page generated in 0.20129 seconds
