Home » Eclipse Projects » DSDP - Target Management » slow connection to Linux sever
slow connection to Linux sever [message #14157] Tue, 21 August 2007 19:07 Go to next message
I use RSE-2.0.0.1-200707061039 runtime for core and ssh only on Eclipse 3.3
and experience very slow connection when trying ssh connection to my Linux.
It takes long time to connect to my Linux and a message shows "Fetching
children of My Home" message on the bottom of Eclipse window.
My remote directories eventually shows up when I click ok on an error
message "operation failed with exception 'Exception
java.lang.IllegalThreadStateException'" .
Here is the error log.
!SESSION 2007-08-21
10:38:23.687 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.rse.ui 4 0 2007-08-21 10:45:49.523
!MESSAGE RSEG1066U: SUB#0:Exception java.lang.IllegalThreadStateException
!STACK 0
at
org.eclipse.rse.services.shells.HostShellProcessAdapter.exit Value(HostShellProcessAdapter.java:85)
at
org.eclipse.rse.internal.subsystems.processes.shell.linux.Li nuxProcessHelper.populateUsernames(LinuxProcessHelper.java:1 32)
at
org.eclipse.rse.internal.subsystems.processes.shell.linux.Li nuxShellProcessService.initService(LinuxShellProcessService. java:190)
at
org.eclipse.rse.subsystems.processes.servicesubsystem.Proces sServiceSubSystem.initializeSubSystem(ProcessServiceSubSyste m.java:195)
at
org.eclipse.rse.core.subsystems.AbstractConnectorService.ini tializeSubSystems(AbstractConnectorService.java:298)
at
org.eclipse.rse.core.subsystems.AbstractConnectorService.con nect(AbstractConnectorService.java:413)
at
org.eclipse.rse.ui.operations.SystemFetchOperation.execute(S ystemFetchOperation.java:243)
at
org.eclipse.rse.ui.operations.SystemFetchOperation.run(Syste mFetchOperation.java:128)
at
org.eclipse.rse.ui.view.AbstractSystemViewAdapter.fetchDefer redChildren(AbstractSystemViewAdapter.java:1970)
at
org.eclipse.ui.progress.DeferredTreeContentManager$1.run(Def erredTreeContentManager.java:196)
Thanks for your help,
Re: slow connection to Linux sever [message #14178 is a reply to message #14157] Wed, 22 August 2007 07:44 Go to previous message
The "IllegalThreadStateException" is already being tracked as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192390
You may want to CC on it.
What seems to be slow is the SSH Processes subsystem. If you
don't really need it, better use an "SSH Only" systemType,
you won't have processes but be faster. Performance of SSH
Processes is tracked as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=175300
If this does not help, please file a new bug for discussing
the issues. It might be related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191374
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Windy wrote:
> Hi
> !SESSION 2007-08-21
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: slow connection to Linux sever [message #569850 is a reply to message #14157] Wed, 22 August 2007 07:44 Go to previous message
Martin Oberhuber
Windy wrote:
> Hi
> !SESSION 2007-08-21
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:slow connection to Linux sever
Next Topic:Custom RSE view - observations & help needed
Current Time: Fri Jul 18 19:53:55 EDT 2025
Powered by FUDForum. Page generated in 0.04298 seconds
