Home » Archived » Visual Editor (VE) » How to parse the VE Model: XMI View.xmi
| How to parse the VE Model: XMI View.xmi [message #141111] |
Wed, 26 September 2007 09:29  |
Originally posted by: caye5200.yahoo.com.cn
Hello
VE hava VE Model: XMI View.xmi,
now ,have a problem ,VE how to read the xmi ?
i want get message to store from this xmi file.
i needs your help.
zxc
| Re: How to parse the VE Model: XMI View.xmi [message #141538 is a reply to message #141528] |
Wed, 03 October 2007 13:13   |
--------------000702080407060806060200
Rich,
Yes, we feel bad that for many of our models even in EMF today we are
still using Rose. We could switch to UML2 but they didn't provide a
good free diagramming tool either, though there is one in the works
now. What we will very soon have instead is a graphical Ecore editor
that's an improvement over the example one from GMF, e.g.,
http://dev.eclipse.org/mhonarc/lists/emft-dev/msg00148.html
This way we can have diagrams that edit Ecore directly and then we can
throw our crusty old Rose models away. Woo hoo!
Rich Kulp wrote:
> It is Open source! The problem was that at the time these projects
> were being created there was no other UML graphical modeling available
> that could be imported into EMF format. At the time Rose was all that
> was available.
> You can still the model in tree form through the EMF Ecore editors on
> the .gemmodel files.
> dominique wrote:
>> There are several models used by ve.
>> You can find them in the subdirectory "rose" of the projects
>> "org.eclipse.ve.core" , "org.eclipse.ve.cde".
>> The files are "jcmmodel.mdl", "cdeModels.mdl", "cdmmodel.mdl" ...
>> If you don't have rational rose software in your PC, you should not
>> be able to read those files.
>> When I realised this fact few weeks ago, I conclude that the Eclipse
>> projects are not really open source projects. The base of a lot of
>> Eclipse projects are using rational rose model files.
>> Those files are in the project, but you cannot view them without
>> rational rose software.
>> regards,
>> Dominique
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Rich,<br>
<br>
that's an improvement over the example one from GMF, e.g., <br>
<blockquote><a
href="http://dev.eclipse.org/mhonarc/lists/emft-dev/msg00148.html">http://dev.eclipse.org/mhonarc/lists/emft-dev/msg00148.html</a><br>
</blockquote>
throw our crusty old Rose models away. Woo hoo!<br>
<br>
<br>
Rich Kulp wrote:
<blockquote cite="mid:fe091c$qj$1@build.eclipse.org" type="cite">It is
Open source! The problem was that at the time these projects were being
created there was no other UML graphical modeling available that could
be imported into EMF format. At the time Rose was all that was
available.
<br>
<br>
<br>
<br>
<br>
<br>
dominique wrote:
<br>
<blockquote type="cite">There are several models used by ve.
<br>
<br>
<br>
<br>
<br>
If you don't have rational rose software in your PC, you should not be
<br>
<br>
<br>
<br>
<br>
regards,
<br>
Dominique
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
--------------000702080407060806060200--
| Re: How to parse the VE Model: XMI View.xmi [message #141560 is a reply to message #141528] |
Thu, 04 October 2007 03:44   |
For me, a project is an Open Source project if the following is true :
1- The community can access to all the source files used to build the software.
2- The community can read and make changes on the source files.
In the case of Eclipse projects based on Rose models files, the first point is OK, but the second is not.
I can get the Rose models files but I cannot view the contents of the files, I cannot change them ...
Imagine that I create a new compiler, for instance C--, and I make a software with this new compiler. I provide the source files of my software to the community (written in C--), and you need to buy my new compiler C-- to make any change in the sofware. Do you think it is an open source project ?
About the EMF Ecore editors, do you really use it to make changes in the models of a project ? You can make a small change with it, but you cannot have a clear view of the project.
About the ".genmodel" and "rose" model files, what is the source files ? If it is ".genmodel", you should remove all the "rose" model from the project, because the "rose" model files will be out of synchronisation when some update will be done on the .genmodel.
For me the situation is not good, and the community cannot work on VE project for this reason.
Regards, Dom
| Re: How to parse the VE Model: XMI View.xmi [message #141570 is a reply to message #141560] |
Thu, 04 October 2007 13:16   |
Dom,
Comments below.
I think all these are true. Though pointing out that you can edit .cat
or .mdl file is hardly a helpful suggestion. The fact that our project
was bootstrapped from these and that the community took a long time to
provide open source equivalents of sufficient quality to replace them is
our only poor excuse.
As I said, you could change them, but that's splitting hairs. At this
point, the best we can do is move in the right direction.
Your point has been made and is valid. I doubt you can even buy Rose 98
anymore. That was two technology revs ago, so it's not as if we are
trying to force you to buy Rose.
Many people do use the Ecore editor directly. Also, the generated code
contains @model annotations and a great many folks use EMF by virtue of
writing such annotations directly.
EMF supports a reload mechanism whereby the Ecore model can be
reimported from its source (an XML Schema, a Rose file, @model
annotations) and they the .genmodel synchronizes itself with the new
version of the Ecore model to preserve all the settings that were in
place for the previous Ecore model.
Well, there are a lot more issues than just the Rose models and the
community has not been terribly active in contributing until lately.
Kudos to Philippe. It's not entirely clear that the Rose models need
to change as a first order of business and it's not the only way to make
changes. Certainly you could modify the Ecore directly and the
committers could backport those changes to the Rose. And as I've
already pointed out, this story is in the process of being transformed
for the current release cycle, so moving in the right direction is the
best folks can do.
> Regards, Dom
| Re: How to parse the VE Model: XMI View.xmi [message #141590 is a reply to message #141581] |
Thu, 04 October 2007 20:07   |
--------------070607040406020501040707
Dom,
Comments below.
dominique wrote:
> Thanks for your reply but you should understand that without the global view of the ve project using the rose files, it seems to be very hard to understand the different packages and classes ...
For EMF we include screen captures of the model for that purpose and
even went through the effort of mapping clicks in the diagram to the
Java Doc for that component:
http://download.eclipse.org/modeling/emf/emf/javadoc/2.4.0/o rg/eclipse/emf/ecore/package-summary.html
So this goal could be accomplished without the tool. Wouldn't it be
nice for a lot of project to provide this type of visual overview?
> The first step is to understand the models not to modify them but to understand the different packages. Without this global view provided by the UML rose files, I think that the price to get the global view using the code and the tree ecore view is very high.
That's certainly true, but that comment applies to almost all of
Eclipse, which is not model based.
> You should try to remove from your memory the nice UML rose views and then, go into the ecore editor and try to understand the different java packages and classes ... Good luck !
I have a really good memory. :-P But of course you are right, I love
these diagrams, the second one in the above link is my all time
favorite. You can understand almost all of Ecore with just that one
picture. A picture is worth way more than a thousand words!
> The UML models are using visual graphs to give an easy way to understand a project. UML is based on graphical views and not tree view like ecore editor. The tree view is useless from an UML point of view and have nothing to do with UML. It is probably the best way to save an UML model, but it is probably the worst way to understand the model.
Well, you keep mentioning UML, but that's certainly not at the top of my
list of cool things. Ecore is at the top of my list. But you really
mean a class diagram and I agree on that point completely.
> It could be nice to get at least a viewer of the rose files, like acrobat reader for acrobat files. We can see the UML graphs but we cannot modify them.
I agree. A screen capture is not much to ask for.
> If this viewer doesn't exist, it could be nice to get some jpeg files with the main UML graphs. It could be a starting point for a technical documentation of the ve project.
> It will help any new comer to make bug fixes.
I guess you want something just like what we did for the EMF project.
Check out these awesome diagrams from the XSD model. You'd have to read
most of the XML Schema specification to get this much information:
http://download.eclipse.org/modeling/emf/emf/javadoc/xsd/2.4 .0/org/eclipse/xsd/package-summary.html
So I agree completely that regardless of the tools used to edit a
graphical representation, having class diagrams in the documentation
would be a very good thing.
> Regards, Dom
<html>
<head>
</head>
Dom,<br>
<br>
Comments below.<br>
<br>
dominique wrote:
<blockquote
cite="mid:1687732936.1771191532017986.JavaMail.root@cp9.dzone.com"
type="cite">
<pre wrap="">Thanks for your reply but you should understand that without the global view of the ve project using the rose files, it seems to be very hard to understand the different packages and classes ...
</pre>
</blockquote>
Java Doc for that component:<br>
<blockquote><a
href=" http://download.eclipse.org/modeling/emf/emf/javadoc/2.4.0/o rg/eclipse/emf/ecore/package-summary.html"> http://download.eclipse.org/modeling/emf/emf/javadoc/2.4.0/o rg/eclipse/emf/ecore/package-summary.html</a><br>
</blockquote>
nice for a lot of project to provide this type of visual overview?<br>
<blockquote
type="cite">
<pre wrap="">
</pre>
</blockquote>
Eclipse, which is not model based.<br>
<blockquote
type="cite">
<pre wrap="">
</pre>
</blockquote>
picture. A picture is worth way more than a thousand words!<br>
<blockquote
type="cite">
<pre wrap="">
</pre>
</blockquote>
my list of cool things. Ecore is at the top of my list. But you
really mean a class diagram and I agree on that point completely.<br>
<blockquote
type="cite">
<pre wrap="">
</pre>
</blockquote>
I agree. A screen capture is not much to ask for.<br>
<blockquote
type="cite">
<pre wrap="">If this viewer doesn't exist, it could be nice to get some jpeg files with the main UML graphs. It could be a starting point for a technical documentation of the ve project.
</pre>
</blockquote>
most of the XML Schema specification to get this much information:<br>
<blockquote><a
href=" http://download.eclipse.org/modeling/emf/emf/javadoc/xsd/2.4 .0/org/eclipse/xsd/package-summary.html"> http://download.eclipse.org/modeling/emf/emf/javadoc/xsd/2.4 .0/org/eclipse/xsd/package-summary.html</a><br>
</blockquote>
would be a very good thing.<br>
<blockquote
type="cite">
<pre wrap="">
Regards, Dom
</pre>
</blockquote>
<br>
</body>
</html>
--------------070607040406020501040707--
| Re: How to parse the VE Model: XMI View.xmi [message #141719 is a reply to message #141508] |
Sat, 13 October 2007 03:02   |
"dominique" <dominique.vincent10@free.fr> wrote in message
news:1943513632.76911191401261808.JavaMail.root@cp9.dzone.com...
projects are not really open source projects. The base of a lot of Eclipse
> Those files are in the project, but you cannot view them without rational
rose software.
> regards,
> Dominique
Good point, but FWIW, i do not have rose, and do not intend to use it as a
new committer on VE.
Most uml diagram tools can importa rose stuff afaik, but this is not
required.
| Re: How to parse the VE Model: XMI View.xmi [message #616644 is a reply to message #141111] |
Wed, 03 October 2007 04:47  |
You can find them in the subdirectory "rose" of the projects "org.eclipse.ve.core" , "org.eclipse.ve.cde".
If you don't have rational rose software in your PC, you should not be able to read those files.
When I realised this fact few weeks ago, I conclude that the Eclipse projects are not really open source projects. The base of a lot of Eclipse projects are using rational rose model files.
Those files are in the project, but you cannot view them without rational rose software.
regards,
Dominique
| Re: How to parse the VE Model: XMI View.xmi [message #616746 is a reply to message #141508] |
Wed, 03 October 2007 10:30  |
It is Open source! The problem was that at the time these projects were
being created there was no other UML graphical modeling available that
could be imported into EMF format. At the time Rose was all that was
available.
> regards,
> Dominique
Rich Kulp
| Re: How to parse the VE Model: XMI View.xmi [message #616747 is a reply to message #141528] |
Rich,
> was available.
>> regards,
>> Dominique
<html>
<head>
</head>
Rich,<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
available.
<br>
<br>
<br>
<br>
<br>
<br>
dominique wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
regards,
<br>
Dominique
<br>
</blockquote>
<br>
</blockquote>
<br>
</body>
</html>
| Re: How to parse the VE Model: XMI View.xmi [message #616748 is a reply to message #141538] |
Wed, 03 October 2007 13:45  |
Hi Ed,
That would be great. I tried the sample GMF one but the problem was it
was too literal in matching the ECore model. It was simply a one-for-one
match to the internal layout of an Ecore file with the nicety of making
it graphical instead. For example if I wanted to add a description to a
property in Rose and in IBM RSA I would simply set the description in
the property sheet. But with the sample GMF I had to create a MetaData
annotation and know the correct id to set on it and the correct setting
to use for the description. It didn't hide all of the internal gorp of
Ecore files and present it in a straight forward manner.
Ed Merks wrote:
> Rich,
Rich Kulp
| Re: How to parse the VE Model: XMI View.xmi [message #616749 is a reply to message #141528] |
Regards, Dom
| Re: How to parse the VE Model: XMI View.xmi [message #616750 is a reply to message #141560] |
Dom,
Comments below.
best folks can do.
> Regards, Dom
| Re: How to parse the VE Model: XMI View.xmi [message #616751 is a reply to message #141570] |
Thu, 04 October 2007 17:06  |
Regards, Dom
| Re: How to parse the VE Model: XMI View.xmi [message #616752 is a reply to message #141581] |
Dom,
Comments below.
> Regards, Dom
<html>
<head>
</head>
Dom,<br>
<br>
Comments below.<br>
<br>
dominique wrote:
<blockquote
type="cite">
</pre>
</blockquote>
<blockquote><a
</blockquote>
<blockquote
type="cite">
<pre wrap="">
</pre>
</blockquote>
<blockquote
type="cite">
<pre wrap="">
</pre>
</blockquote>
<blockquote
type="cite">
<pre wrap="">
</pre>
</blockquote>
<blockquote
type="cite">
<pre wrap="">
</pre>
</blockquote>
<blockquote
type="cite">
</pre>
</blockquote>
<blockquote><a
</blockquote>
<blockquote
type="cite">
<pre wrap="">
Regards, Dom
</pre>
</blockquote>
<br>
</body>
</html>
| Re: How to parse the VE Model: XMI View.xmi [message #616765 is a reply to message #141508] |
rose software.
> regards,
> Dominique
required.
| Re: How to parse the VE Model: XMI View.xmi [message #616767 is a reply to message #141560] |
Sat, 13 October 2007 03:05  |
news:905858141.238861191483916672.JavaMail.root@cp9.dzone.com...
software.
Domique: relax:
read my lips: we do not use Rose anymore on the ve project.
In fact I even had removed the "rose" nature from our ve CVS :-)
For now, working straight with ecore editor is good enough for many tasks.
Current Time: Thu Nov 06 23:05:19 EST 2025
Powered by FUDForum. Page generated in 0.30643 seconds
