Re: Xtext: problem in editor when creating a new file [message #1414878 is a reply to message #1414836] |
Mon, 01 September 2014 09:53   |
Interesting: it also happens when i compeltely empty an existing file, and open that in the editor. i get this validation error:
Description Resource Path Location Type
mismatched input '<EOF>' expecting 'package' TEST.wdl /com.wamas.wms.dbal.core/wdl/core line: 1 /com.wamas.wms.dbal.core/wdl/core/TEST.wdl WDL Problem
which is expected. But when opening, i first get this (this does not happen when creating the file and eclipse opens the editor for me - only when i manually open an empty file from the package explorer):
java.lang.IllegalStateException: Ambiguous methods [public boolean com.wamas.wdl.ui.outline.WDLOutlineTreeProvider._isLeaf(com.wamas.wdl.wDL.ConnectionRole), public boolean com.wamas.wdl.ui.outline.WDLOutlineTreeProvider._isLeaf(com.wamas.wdl.wDL.Connection), public boolean com.wamas.wdl.ui.outline.WDLOutlineTreeProvider._isLeaf(com.wamas.wdl.wDL.Attribute), public boolean com.wamas.wdl.ui.outline.WDLOutlineTreeProvider._isLeaf(com.wamas.wdl.wDL.Property)] for params [null]
at org.eclipse.xtext.util.PolymorphicDispatcher.handleAmbigousMethods(PolymorphicDispatcher.java:308)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:283)
at org.eclipse.xtext.ui.editor.outline.impl.DefaultOutlineTreeProvider._createNode(DefaultOutlineTreeProvider.java:123)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291)
at org.eclipse.xtext.ui.editor.outline.impl.DefaultOutlineTreeProvider.createNode(DefaultOutlineTreeProvider.java:111)
at com.wamas.wdl.ui.outline.WDLOutlineTreeProvider._createChildren(WDLOutlineTreeProvider.java:44)
at org.eclipse.xtext.ui.editor.outline.impl.DefaultOutlineTreeProvider.createChildren(DefaultOutlineTreeProvider.java:84)
at org.eclipse.xtext.ui.editor.outline.impl.AbstractOutlineNode$1.process(AbstractOutlineNode.java:98)
at org.eclipse.xtext.ui.editor.outline.impl.AbstractOutlineNode$1.process(AbstractOutlineNode.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:36)
at org.eclipse.xtext.ui.editor.outline.impl.DocumentRootNode$1.exec(DocumentRootNode.java:62)
at org.eclipse.xtext.ui.editor.outline.impl.DocumentRootNode$1.exec(DocumentRootNode.java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:62)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.readOnly(XtextDocument.java:246)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:84)
at org.eclipse.xtext.ui.editor.outline.impl.DocumentRootNode.readOnly(DocumentRootNode.java:59)
at org.eclipse.xtext.ui.editor.outline.impl.AbstractOutlineNode.getChildren(AbstractOutlineNode.java:95)
at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage.addChildren(OutlinePage.java:149)
at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage.getInitiallyExpandedNodes(OutlinePage.java:139)
at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage$2.exec(OutlinePage.java:130)
at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage$2.exec(OutlinePage.java:1)
at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage.initializeTreeContent(OutlinePage.java:128)
at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage.configureTree(OutlinePage.java:119)
at org.eclipse.xtext.ui.editor.outline.impl.OutlinePage.createControl(OutlinePage.java:89)
at org.eclipse.ui.views.contentoutline.ContentOutline.doCreatePage(ContentOutline.java:137)
at org.eclipse.ui.part.PageBookView.createPage(PageBookView.java:412)
at org.eclipse.ui.part.PageBookView.partActivated(PageBookView.java:753)
at org.eclipse.ui.views.contentoutline.ContentOutline.partBroughtToTop(ContentOutline.java:212)
at org.eclipse.ui.part.PageBookView$4.partBroughtToTop(PageBookView.java:1059)
at org.eclipse.ui.internal.WorkbenchPage$23.run(WorkbenchPage.java:4929)
at org.eclipse.ui.internal.WorkbenchPage.firePartBroughtToTop(WorkbenchPage.java:4927)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPage.java:4912)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partBroughtToTop(WorkbenchPage.java:199)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$6.run(PartServiceImpl.java:239)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartBroughtToTop(PartServiceImpl.java:237)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.access$4(PartServiceImpl.java:235)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:92)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4491)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:576)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:543)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:610)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:322)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1034)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3112)
at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:3034)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:3016)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3012)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2976)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2967)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:534)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:493)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:360)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:167)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:268)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:233)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:47)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
and after that the above exception. It seems the initial problem is just a follow up from the (opbviously not shown) error...?
the ambigous method call for "null" looks interesting. why call this with null at all? Also this seems to only hit the _isLeaf method of the outline tree provider... i removed all of my specialisations, just in case, and tried again -> empty an existing file -> the outline view keeps without updating, and this is thrown:
at org.eclipse.xtext.ui.editor.outline.impl.DefaultOutlineTreeProvider._isLeaf(DefaultOutlineTreeProvider.java:169)
open that file from scratch and the same happens, followed by the already in use exception.
[Updated on: Mon, 01 September 2014 10:15] by Moderator
FUDForum. Page generated in 0.25305 seconds
