Home » Eclipse Projects » Remote Application Platform (RAP) » Nebula grid repo RAP 2.3 requires RAP 3.0
Nebula grid repo RAP 2.3 requires RAP 3.0 [message #1414871] Mon, 01 September 2014 09:42 Go to next message
I'm working with RAP 2.3 -> my target is set to 2.3.
I've edited the target and added http://download.eclipse.org/rt/rap/incubator/2.3/nebula-grid/ .
I added nebula grid and gridviewer to my manifest and added it to the runconfigurations.
When I start the application then I get the following exception :
!ENTRY org.eclipse.rap.nebula.widgets.grid 4 0 2014-09-01 15:29:26.737
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rap.nebula.widgets.grid [50]
Unresolved requirement: Require-Bundle: org.eclipse.rap.rwt; bundle-version="[3.0.0,4.0.0)"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Am I doing something wrong?
It seems to me that nebula 2.3 requires RAP 3.0 -> 4.0
Kind regards
Re: Nebula grid repo RAP 2.3 requires RAP 3.0 [message #1414892 is a reply to message #1414871] Mon, 01 September 2014 10:32 Go to previous messageGo to next message
please file a bugzilla and we will look on it as soon as possible.
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Nebula grid repo RAP 2.3 requires RAP 3.0 [message #1414893 is a reply to message #1414871] Mon, 01 September 2014 10:35 Go to previous messageGo to next message
Last week I found a similar problem in the dropdown component... it looks like we've had some versions in the incubator repository that were too young.
Can you try to reload your target? I fixed the composite p2 repository.
If you've got a version 0.2.0.20140612-1421 or later you'll have this problem with the 3.0 version requirement. If you are using 20140611-1600 or earlier you should be fine.
Hope that helps,
Markus
Re: Nebula grid repo RAP 2.3 requires RAP 3.0 [message #1414907 is a reply to message #1414893] Mon, 01 September 2014 11:19 Go to previous message
Yes,
thank you for the quick update !!
No bundle problems anymore.
For the completness,
reloading target did not get the new update.
I had to delete it from my target, apply and then add it again to the target then I saw the ....-1600 update.
Kind regards,
Wim Anckaert
[Updated on: Mon, 01 September 2014 11:20] by Moderator
Previous Topic:ScrolledComposite does not work properly unless you explicitly set the size of the scrolled content
Next Topic:Rap ComboBox selection handling
Current Time: Sun Aug 31 14:22:11 EDT 2025
Powered by FUDForum. Page generated in 0.05006 seconds
