NoSQL and Scout [message #1414838] |
Mon, 01 September 2014 08:02  |
Is it possible to use a non-relational databases (similar to MongoDB, Oracle NoSQL, etc..) In the Scout?
Re: NoSQL and Scout [message #1415227 is a reply to message #1414856] |
Tue, 02 September 2014 07:08   |
@Dennis Geesen:
Initially, my question about the possibility of using NoSQL, I wanted to find out the possibility of using other data storage and processing systems in Scout.
Quote:May I ask you why or for what you want to use NoSQL?
Supposed to solve the problem with a large data processing (Big Data), scalability and clustering. Taken as a basis: document processing and quick access to pictures on the key values of the objects.
Quote:I'm asking, because NoSQL can be everything: key-value, document store, column store or even graph database like neo4j.
What kind of technology use has not been resolved, although as I wrote above, this is likely to Document-Oriented Store or Key-Value Store.
About ACID:
I agree with you that most NoSQL systems do not guarantee requirements ACID, but in the developed system proposed to use NoSQL and relational database systems. I think that it would be difficult to solve this kind of problem. But this is solved, is not it?
FUDForum. Page generated in 0.07898 seconds
