Home » Eclipse Projects » Eclipse Scout » MSSQL Service how to?
MSSQL Service how to? [message #1414810] Mon, 01 September 2014 06:43 Go to next message
Hello how to add MsSQL service to work with MSSQL database in scout? Im am using Eclipse Luna
Re: MSSQL Service how to? [message #1414824 is a reply to message #1414810] Mon, 01 September 2014 07:24 Go to previous messageGo to next message
Solution to this issue here:
https://wiki.eclipse.org/Scout/HowTo/Write_a_jdbc_connection_bundle
It would be nice if you've been paying attention to these links:
https://wiki.eclipse.org/Scout/Tutorial/Minicrm/Set_up_SQL_Service
https://wiki.eclipse.org/Scout/Concepts/Sql_Service
https://wiki.eclipse.org/Scout/Tutorial/4.0/Add_JDBC_Drivers_for_Eclipse_Scout
Re: MSSQL Service how to? [message #1414830 is a reply to message #1414810] Mon, 01 September 2014 07:38 Go to previous messageGo to next message
MsSQL ist not provided in our market place add-on: JDBC Drivers for Eclipse Scout. You need to write one by yourself: How-To: Write a jdbc connection bundle.
PS: Some people on this forum are using an Microsoft Database. Maybe they can share some code...
Re: MSSQL Service how to? [message #1415167 is a reply to message #1414830] Tue, 02 September 2014 04:35 Go to previous messageGo to next message
this is my code for using MsSQL:
public class Mpx1SqlService extends AbstractSqlService implements IService2 {
  protected String getConfiguredJdbcDriverName() {
    return "com.microsoft.sqlserver.jdbc.SQLServerDriver";
  protected java.lang.Class<? extends ISqlStyle> getConfiguredSqlStyle() {
    return RidMsSqlStyle.class;
public class RidMsSqlStyle extends MSSQLSqlStyle {
  private static final long serialVersionUID = 1L;
  public void testConnection(Connection conn) throws SQLException {
  public boolean isBlobEnabled() {
    return false;
  public boolean isClobEnabled() {
    return false;
  public boolean isLargeString(String s) {
    return false;
  protected int getMaxListSize() {
    return 0;
You have to add the driver. I have done this is an seperate bundle.
Re: MSSQL Service how to? [message #1416029 is a reply to message #1415167] Thu, 04 September 2014 03:27 Go to previous message
Hi Bertin,
Thanks for sharing your solution.
Previous Topic:Best practice: TablePageData + Pagination
Next Topic:New wizard in SWT app
Current Time: Fri Jul 18 20:17:34 EDT 2025
Powered by FUDForum. Page generated in 0.07867 seconds
