Home » Modeling » ATL » Generated model in bad format(ATL transformation)
Generated model in bad format [message #1414768] Mon, 01 September 2014 05:07 Go to next message
I have a small set of ATL rules to refine a BPMN2.0 model into another BPMN2.0 model.
The problem I encounter is that the nested elements are shown in a wierd format.
For instance a Process inside a definition appears as:
<rootElements xsi:type="bpmn2:Process" id="process_1" name="Default Process">
rather than
<bpmn2:Process id="process_1" name="Default Process">
Also the namespace are not shown properly in the header part of xml. So instead of
the generated output has the following format:
<xmi:XMI xmi:version="2.0" xmlns:xmi="xxx" xmlns:xsi="xxx" xmlns:bpmn2=xxx>
rather than
<bpmn2:definitions xmlns:xsi="xxx" xmlns:bpmn2="xxx" xmlns:bpmndi="xxx" xmlns:dc="xxx" xmlns:di=" xxx" id="Definitions_1" targetNamespace="xxx">
The followings are my ATL rules, the BPMN20 ecore matamodel, the input and the output file. I am using the BPMN2.0 ecore from eclipse.org/bpmn2-modeler.
Does anyone have an idea what might be wrong?
Many thanks in advance,
Behnaz
--@nsURI bpmn2=xxx
module b2b;
create OUT: bpmn2out from IN: bpmn2;
rule transaction {
from
t : bpmn2!Transaction
to
b : bpmn2out!Transaction(name <- t.name, id <- t.id)
rule process {
from
t : bpmn2!Process
to
c : bpmn2out!Process(name <- t.name, id <- t.id
, supports <- t.supports
, processType <- t.processType
, flowElements <- t.flowElements
rule definition {
from
t : bpmn2!Definitions(not false)
to
c : bpmn2out!Definitions(id <- t.id
,rootElements <- t.rootElements
, diagrams <- t.diagrams
rule baseElement {
from
t : bpmn2!BaseElement(not t.oclIsTypeOf(bpmn2!Definitions) and
not t.oclIsTypeOf(bpmn2!Process) and not t.oclIsTypeOf(bpmn2!Transaction)
and not t.oclIsKindOf(bpmn2!Event) and not t.oclIsKindOf(bpmn2!EventDefinition)
and not t.oclIsKindOf(bpmn2!Task) and not t.oclIsKindOf(bpmn2!FlowElement))
to
c : bpmn2out!BaseElement(id <- t.id)
rule startEvent {
from
a : bpmn2!StartEvent
to
d : bpmn2out!StartEvent(name <- a.name)
rule endEvent {
from
a : bpmn2!EndEvent
to
d : bpmn2out!EndEvent(name <- a.name)
rule task {
from
a : bpmn2!Task
to
d : bpmn2out!Task(name <- a.name)
rule sequenceFlow {
from
a : bpmn2!SequenceFlow
to
d : bpmn2out!SequenceFlow(name <- a.name)
rule cancelEventDefinition {
from
a : bpmn2!CancelEventDefinition
to
d : bpmn2out!CancelEventDefinition(id <- a.id)
P.S. I had to remove URL in order to post my message. Please see the attachments.
  • Attachment: sn.atl
    (Size: 1.43KB, Downloaded 408 times)
  • Attachment: process_1.bpmn
    (Size: 5.87KB, Downloaded 439 times)
  • Attachment: o.bpmn
    (Size: 0.94KB, Downloaded 347 times)
  • Attachment: BPMN20.ecore
    (Size: 255.71KB, Downloaded 313 times)
Re: Generated model in bad format [message #1414776 is a reply to message #1414768] Mon, 01 September 2014 05:25 Go to previous messageGo to next message
You get the xmi wrapper as your ATL isn't creating a valid output model. For example you have StartEvent, EndEvent incorrectly transformed. If you have all the elements tarnsformed correctly then the nesting in the XML of the ouput model will be correct and you will not get the xmi wrapper. So basically the xmi element is there because you have multiple root elements in your outpur instead of one i.e. bpmn2:definitons
Ronan
Re: Generated model in bad format [message #1416042 is a reply to message #1414776] Thu, 04 September 2014 04:07 Go to previous messageGo to next message
Thanks Ronan for your reply.
I can't agree more with you that the output is wrong. However, the cause is still unclear to me.
Mentioning the rootElements, I only have one rootElement that is the process in the output.
The rules generating Start and End events are very basic. It seems to me they generate the correct element (if I make the condition of other rules false, I get the correct results from these rules), but the problem is when they are set inside another element e.g rootElement.
rule startEvent {
from
to
rule endEvent {
from
a : bpmn2!EndEvent
to
Any thought?
B
Re: Generated model in bad format [message #1416141 is a reply to message #1416042] Thu, 04 September 2014 08:25 Go to previous messageGo to next message
I have also notices in java APIs for writing the model into a file, the user guide in camunda website suggests to "disable generation of xsi:schemaLocation because that may generate wrong entries"
By
Map<String, Boolean> options = new HashMap<String, Boolean>();
options.put(XMLResource.OPTION_SCHEMA_LOCATION, Boolean.FALSE);
resource.save(out, options);
I was wondering if it has any connection to my problem.
B
Re: Generated model in bad format [message #1416146 is a reply to message #1416042] Thu, 04 September 2014 08:32 Go to previous messageGo to next message
You must write some ATL inside your rules to say where the elements should be nested. So for example where is the code to nest the EndEvent and StartEvent into a container? ATL can't guess how your model should be generated you need to explicitly state how the transform will work. If you don't state where the elements should be nested you will get them all at the root, like you have.
Ronan
Re: Generated model in bad format [message #1416153 is a reply to message #1416146] Thu, 04 September 2014 08:49 Go to previous messageGo to next message
Sure Ronan and I am telling ATL in the following rules:
rule process {
from
t : bpmn2!Process
to
rule definition {
from
to
which says the flowElements should go inside Process and rootElement should be nested in definition.
Their place in the output is also correct but the generated tag for them is incorrect.
Re: Generated model in bad format [message #1416158 is a reply to message #1416153] Thu, 04 September 2014 09:02 Go to previous messageGo to next message
I don't know the BPMN MetaModel so well but it looks to me like the generated elements are *not* in the right place. The element names are wrong because they are not postioned correctly. When you get your nesting fixed they will be serialized correctly. So from what I can see your transformation is incomplete. For example the rule startEvent is running but you don't have it matched inside another rule, thus the output of startEvent goes int eh wrong place. Fix the transform and the output will serialize correctly.
Ronan
Re: Generated model in bad format [message #1783105 is a reply to message #1416158] Wed, 07 March 2018 19:41 Go to previous message
I know this post is old but I have the same problem do you fix it? if yes how?
Previous Topic:[EMFTVM] generate model
Next Topic:ATL how to Hide Tag?
Current Time: Fri Jul 25 22:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.28592 seconds
