Home » Modeling » TMF (Xtext) » [Xpand/Xtend] : xtext extensions importation
[Xpand/Xtend] : xtext extensions importation [message #1414451] Sun, 31 August 2014 06:38 Go to next message
I write a xtend module where I import some xtend modules :
«EXTENSION org::eclipse::xtext::EcoreUtils»
«EXTENSION org::eclipse::xtext::generator::Naming»
I've added in dependencies :
org.eclipse.xtext
and
org.eclipse.xtext.generator
plugins
But:
whereas all is fine for
raises an error :
Error while importing extension: Resource org::eclipse::xtext::generator::Naming
not found.
What is destabilizing : at the same time, I able to import a java class of the same package, org.eclipse.xtext.generator.
What's the ""fuck"" ?
Someone can help me ?
Thanks a lot by advance
[Updated on: Sun, 31 August 2014 07:05] by Moderator
Re: [Xpand/Xtend] : xtext extensions importation [message #1414464 is a reply to message #1414451] Sun, 31 August 2014 07:24 Go to previous messageGo to next message
i have no idea on that
xtend 1 question should be asked in the m2t forum.
are you writing a own fragment or what is that reason that you are doing this?
- are you sure the path for the .ext file is <somesourcefolder>/org/eclipse/xtext/generator/Naming.ext and the project has xtend/xpand nature?
- does the generator bundle export that package?
- happens the error in the editor or running the code.
Re: [Xpand/Xtend] : xtext extensions importation [message #1414610 is a reply to message #1414464] Sun, 31 August 2014 18:26 Go to previous messageGo to next message
Running code conducts to this :
2964 INFO CompositeComponent - Generator(generator): generating 'Root::Root FOR model' => src-gen
3249 ERROR AbstractExpressionsUsingWorkflowComponent - Error in Component generator of type org.eclipse.xpand2.Generator:
EvaluationException : No Definition 'Root::Root for List' found!
[23,27] on line 1 'EXPAND Root::Root FOR model'
Does it mean my xpand code is valid because this message occurs whether the faulty extensions code is present or not ?
Re: [Xpand/Xtend] : xtext extensions importation [message #1414725 is a reply to message #1414610] Mon, 01 September 2014 02:49 Go to previous messageGo to next message
HI,
it said that the workflow calls the template with a list but is not declared
Re: [Xpand/Xtend] : xtext extensions importation [message #1414737 is a reply to message #1414725] Mon, 01 September 2014 03:26 Go to previous messageGo to next message
This is what astonishes me because it is not supposed to be a List.
Here is the workflow that raises this error:
<?xml version="1.0" encoding="ISO-8859-1"?>
<workflow>
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" >
  <platformUri value=".."/>
</bean>
<component id="dirCleaner"
  class="org.eclipse.emf.mwe.utils.DirectoryCleaner"
  directory="src-gen"/>
<!-- load model and store it in slot 'model' -->
<component class="org.eclipse.xtext.mwe.UriBasedReader">
  <uri value="platform:/resource/my.generator.project/data/Xtext.xtext" />
  <register class='org.eclipse.xtext.XtextStandaloneSetup'/>
  <load slot='model'/>
</component>
 <component id="generator" class="org.eclipse.xpand2.Generator" skipOnErrors="true">
	  <expand value="Root::Root FOR model"/>
	  <fileEncoding value="ISO-8859-1"/>
	  <outlet path="src-gen">
	   <postprocessor class="org.eclipse.xpand2.output.JavaBeautifier"/>
	  </outlet>
	</component>
</workflow>
And this is the template called:
«IMPORT xtext»
«DEFINE grammar FOR Grammar»
«ENDDEFINE»
Re: [Xpand/Xtend] : xtext extensions importation [message #1414739 is a reply to message #1414737] Mon, 01 September 2014 03:28 Go to previous messageGo to next message
<expand value="Root::Root FOREACH model"/>
Re: [Xpand/Xtend] : xtext extensions importation [message #1414758 is a reply to message #1414739] Mon, 01 September 2014 04:38 Go to previous messageGo to next message
Yep ! You are great.
I received a more obscur message now :
Workflow interrupted. Reason: No Definition 'Root::Root for org::eclipse::xtext::impl::GrammarImpl' found!
I can't understand because the workflow worked pretty well with the UML tutorial example.
Let me guess ... org.eclipse.xtext.impl doens't need to be exported at least ?!
Re: [Xpand/Xtend] : xtext extensions importation [message #1414763 is a reply to message #1414758] Mon, 01 September 2014 04:53 Go to previous messageGo to next message
which metamodel did you configure in the generator and which is in the templates.
looks like the workflow uses java beans
Re: [Xpand/Xtend] : xtext extensions importation [message #1414782 is a reply to message #1414763] Mon, 01 September 2014 05:37 Go to previous messageGo to next message
My source codes remain the same as presented in this topic
whereas my configuration is the following :
https://lh5.googleusercontent.com/tBxtnHlM0Kdy2pkWvf7JvX0S7Mqz9G738FNq_bCH3rdmuChVKMyP2Oi-RxGbTgqcE9td5fjBzhc=w1349-h736
runRoot.mwe is modified as you've suggested :
<workflow>
</bean>
</component>
	  </outlet>
	</component>
</workflow>
[Updated on: Mon, 01 September 2014 05:43] by Moderator
Re: [Xpand/Xtend] : xtext extensions importation [message #1414785 is a reply to message #1414782] Mon, 01 September 2014 05:44 Go to previous messageGo to next message
The Question was: how does the template look like
Re: [Xpand/Xtend] : xtext extensions importation [message #1419593 is a reply to message #1414785] Mon, 08 September 2014 17:17 Go to previous message
Indeed, I guess you couldn't see my screenshot (with template code, config, console messages, ...). The actual edit is the template, Root.xpt :
https://lh5.googleusercontent.com/t2-0JYzaEd24F8Hye9YkOJwUdabi1IaagAtFdCNuwZ7bvdTSjFReqhCPxmoAySqw05L-=w1146-h782
Here is what you can see on screenshot above :
«EXTENSION org::eclipse::xtext::generator::parser::antlr::AntlrGrammar»
«EXTENSION org::eclipse::xtext::generator::parser::antlr::Parser»
«IMPORT xtext»
«ENDDEFINE»
[Updated on: Mon, 08 September 2014 17:23] by Moderator
Previous Topic:Simple New Grammar
Next Topic:Xtext: Cross-Referenzce + JvmTypeReference
Current Time: Sun Jul 27 02:22:55 EDT 2025
Powered by FUDForum. Page generated in 0.04678 seconds
