Home » Newcomers » Newcomers » Command Prompt Issues(Command Prompt Doesn't Open while Program is Running)
Command Prompt Issues [message #1414665] Sun, 31 August 2014 22:38 Go to next message
Hi, I am new to forums and to programming using Eclipse so bear with me. I have downloaded the Eclipse software for a C programming class, and have edited the path for the environment variables. My problem is that when I run my code, my command prompt window does not pop up. My eclipse application tells me on the console tab at the bottom that the code is in fact running, but the command window is no where to be found. The code even runs correctly if I open the command prompt manually and navigate to the executable file located inside the Debug folder of my current project. If any one has any answers as to why I might be experiencing this issue, please let me know. I will be glad to give any additional information, as well, that could help find the culprit of this issue. Thanks in advance.
Re: Command Prompt Issues [message #1414914 is a reply to message #1414665] Mon, 01 September 2014 11:43 Go to previous message
You should post your question in the Eclipse CDT forum as one of the
sticky posts at the top of this forum prompted you to do.
Previous Topic:Dynamic Help/Help Content do not open.
Next Topic:Can't Update Eclipse 3.7.2
Current Time: Wed Jul 23 17:04:38 EDT 2025
Powered by FUDForum. Page generated in 0.06173 seconds
