Cant add .jar to target plattform [message #1414498] |
Sun, 31 August 2014 09:53  |
Hello everybody!
I'm trying to add the new xtend lib (2.62) to my target plattform.
I downloaded the .jar files (xtend.lib,xbase.lib), and copied them (within eclipse) into a subfolder (plugins) of my active target plattform.
But when I go to Window -> Pref. -> Plugin Dev. -> target plattform (choosing then edit, with the correct plattform marked) I cant find the new xtend lib (only the old one, 2.31 wich was there before).
What else do I have to do? (Refreshenig all projects or restarting eclipse does not work).
One xtend Template I wanted to use says "Add xtend libs to classpath" as quickfix (clicking it does not work...)
Re: Cant add .jar to target plattform [message #1415728 is a reply to message #1414771] |
Wed, 03 September 2014 09:27   |
On 01/09/2014 11:19, alloisxp alloisxp wrote:
> Thanks for your answer!
> Im new to plugin-dev too, but I thought the concept of the
> target-plattform means a collection of plugins that are usable by your
> plugin-project when you point to this target plattform.
> So I thought when I copy a .jar file into this target plattform folder
> its like copying a .jar into a classpath (in standard java projects)?
> Is there something else I have to do? (he does not find the new xtend
> lib when I want to add it under dependencys for a plugin, only the old
> lib, but the jar files are in the same folder... ?? Im confused...)
the target platform is based on installed bundles, thus, just copying
..jar is not enough, as far as I know...
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
FUDForum. Page generated in 0.10311 seconds
