Home » Newcomers » Newcomers » Eclipse launcher unable for find shared library error(Unable to launch eclipse.)
Eclipse launcher unable for find shared library error [message #1006310] Wed, 30 January 2013 13:57 Go to next message
I downloaded and unzipped eclipse-cpp-juno-win32-x86-64.zip. I have Java(TM) SE Runtime Environment (build 1.6.0_07-b06) installed. Whenever I launce eclipse.exe I get an errror dialog displayed stating "The Eclipse executable launcher was unable to locate its companion shared library. I get the same error message when using eclipse downloaded with eclipse-jee-juno-SR1-win32-x86_64.zip. I've tried searching the eclipse executable for the shared library name, but was unable to find a string matching a shared library (*.dll). The eclipse.ini file has reference to a launcher.library entry. The path listed with the launcher.library exists with an eclipse_1503.dll file within it. I tried adding the dll file name to the path, but it didn't solve the problem. Any help will be greatly appreciated.
Re: Eclipse launcher unable for find shared library error [message #1006367 is a reply to message #1006310] Thu, 31 January 2013 00:15 Go to previous messageGo to next message
John,
Is the JRE being used by your launcher (and used within your IDE as the
target) also a 64 bit JRE?
Re: Eclipse launcher unable for find shared library error [message #1008070 is a reply to message #1006310] Fri, 08 February 2013 12:36 Go to previous messageGo to next message
Although I'm not using windows much, this error happened to me as well
when I unzipped eclipse into a deep folder structure (don't remember the
number of folders...)
have you tried unzipping it, let's say, into C:\ directly?
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Re: Eclipse launcher unable for find shared library error [message #1155541 is a reply to message #1008070] Fri, 25 October 2013 20:40 Go to previous messageGo to next message
I found a lot of material and 'solutions', I will help with the one I found:
The problem was that WinRar, when unzipping (unraring), creates a folder with the same name as the .zip (.rar), and inside another one, again, with the same name!!! The solution is simple: Copy and paste the inner elements into the outer, geniune, folder, and delete the inner one. That way, the route will be OK as read from the launcher.
Re: Eclipse launcher unable for find shared library error [message #1414447 is a reply to message #1006310] Sun, 31 August 2014 06:21 Go to previous messageGo to next message
I had the same problem, installing it Eclipse on Win7, the my problem was related to that I copied the Eclipse file to my desktop and tried to run it from there, I removed the copy and created a short-cut instead and then it works.
Re: Eclipse launcher unable for find shared library error [message #1554009 is a reply to message #1414447] Thu, 08 January 2015 20:48 Go to previous messageGo to next message
Ok! Friggin A! I did the same thing and it worked. Thanks for posting this Very Happy .
Re: Eclipse launcher unable for find shared library error [message #1719625 is a reply to message #1155541] Sun, 10 January 2016 05:24 Go to previous messageGo to next message
Thanks for your help.
It applied to my Win 10 (updated from Win 7 32-bit) machine.
I tried your suggestion below knowing that it related to inner elements - I re-extracted the archive zip files and launched eclipse executable with success. The inner most eclipse executable just would not work but the outer one worked. So deleted the inner most entry.
Kam
Re: Eclipse launcher unable for find shared library error [message #1790966 is a reply to message #1006310] Wed, 20 June 2018 12:15 Go to previous messageGo to next message
Guys,
there is a simple solution for this. Or at least a good way to diagnose this:
open your eclipse.ini and check the path of:
--launcher.library
C:\Users\<yourUsername_or_path_toBundlepool>\.p2\pool\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108-1834
As some others replied already. Another reason can be, that the eclipse installation or RCP is installed in a too deep path under Windows. Moving the whole Eclipse Installation or RCP can help.
Re: Eclipse launcher unable for find shared library error [message #1793620 is a reply to message #1006310] Sat, 11 August 2018 20:25 Go to previous message
For me, I had to delete the .p2 directory (sibling of the AppData directory) and the .eclipse directory (also sibling of the AppData directory). Then I deleted the Eclipse installation, etc., and the installation file that I'd downloaded. I also deleted all registry entries that contained eclipse. Then I downloaded the installation file again and installed Eclipse and then it worked.
I think I got into this mess because I had to do a system restore to fix my start menu (it wasn't working).
Previous Topic:Internal implementation of java doc hover view feature in Eclipse
Next Topic:Warning: You are installing software that contains unsigned content.
Current Time: Tue Jul 22 01:19:29 EDT 2025
Powered by FUDForum. Page generated in 0.54755 seconds
