Subcontainer without semantic element [message #1414098] |
Sat, 30 August 2014 04:29  |
Hi all,
is it possible to have a container (just for grouping sub elements) without
a dedicated metamodel element?
Example use case: a class contains fields and operations. When using a
VerticalStack layout it is desired to have containers for these child
elements instead of having only a class container and direct sub nodes for
My intermediate solution for this is using sub containers which have [self/]
as semantic element assigned. This works fine except that validation markers
appear on both the class container as well as the child containers.
Thus my question is how this could be improved.
TIA,
Axel
Re: Subcontainer without semantic element [message #1416078 is a reply to message #1415381] |
Thu, 04 September 2014 05:22  |
Hi Axel,
not sur I understand your question :
- If you want to customize the validation behavior, you can register you
own EValidator (standard emf validation) or add Validation Rules [1] in
your VSM
- If you want to customize the decorator
(SiriusValidationDecoratorProvider) I'm not sure this is possible. It is
contribued by the org.eclipse.sirius.diagram.ui plugin through the
org.eclipse.gmf.runtime.diagram.ui.decoratorProviders extension point.
Alex
[1]
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#validation
Le 02/09/2014 18:42, Axel Guckelsberger a écrit :
> Hi Alex,
> thanks for your advice.
> Do you see any possibility to customise the validation marker's behaviour?
> Regards,
> Axel
> Alex Lagarde wrote:
>> Hi Axel,
>> indeed, Node & Container Mappings must be associated to a semantic
>> element. So the solution you used (using a sub-container with [self/] as
>> Semantic Candidate Expression) is the best one I can imagine.
>> Regards,
>> Alex
>> Le 30/08/2014 10:29, Axel Guckelsberger a écrit :
>>> Hi all,
>>> without a dedicated metamodel element?
>>> for fields and operations.
>>> [self/] as semantic element assigned. This works fine except that
>>> validation markers appear on both the class container as well as the
>>> child containers.
>>> TIA,
>>> Axel
Alex Lagarde - Obeo
Need professional services for Sirius?
http://www.obeodesigner.com/sirius/
FUDForum. Page generated in 0.24094 seconds
