Home » Archived » Test and Performance Tools Platform (TPTP) » How to trace with TPTP ?
How to trace with TPTP ? [message #141363] Thu, 26 March 2009 07:19 Go to next message
From this kind of Java code :
package testtptp;
public class Start {
Aaa aaa = new Aaa();
aaa.doSomething();
Code :
package testtptp;
public class Aaa {
private int i = 0;
public Aaa() {
setI(getI() + 1);
public void doSomething() {
Bbb bbb = new Bbb();
bbb.doOtherThing();
private void setI(int i) {
this.i = i;
private int getI() {
return i;
Code :
package testtptp;
public class Bbb {
private int d=15;
public void doOtherThing() {
setD(getD() + 1);
private void setD(int d) {
this.d = d;
private int getD() {
return d;
I would like to get this kind of trace file:
Trace File:
Start.java main
Aaa.java Aaa()
Aaa.java GetI()
Aaa.java SetI()
Aaa.java doSomething()
BBB.java doOtherThing()
BBB.java GetD()
BBB.java SetD()
Does TPTP can do this kind of job ?
If yes, somebody can tell me how to do the job step by step ?
Pierre8r
Re: How to trace with TPTP ? [message #141402 is a reply to message #141363] Fri, 27 March 2009 09:46 Go to previous messageGo to next message
You could get something like this by profiling to add Common Base
Events; see
http://www.eclipse.org/tptp/monitoring/documents/tutorials/t ptp_btm_setup_4.5.html#2.5
for a description of how this is done.
Dave Skeen
Re: How to trace with TPTP ? [message #141412 is a reply to message #141402] Sat, 28 March 2009 17:00 Go to previous messageGo to next message
In the tutorial they speak about :
From the Profile Configuration screen select the Monitor tab -> Common
Base Event Analysis under the Instrument Collector.
I find nothing about Common Base Event.
http://picasaweb.google.com/lh/photo/RnuCzReEQChai0PdaSInfg? feat=directlink
I work with Release Build: TPTP-4.5.2.
Re: How to trace with TPTP ? [message #141456 is a reply to message #141363] Mon, 30 March 2009 11:23 Go to previous messageGo to next message
Hi Pierre8r,
You may want to consider using TPTP ProbeKit to trace the stack of your
application run into a trace file of your format.
See here for detail on how to create on and configure.
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.hyades.probekit.doc.user/topics/c_toc_probekit.htm
Eugene
"Pierre8r " <pierre8r-eclipse@yahoo.fr> wrote in message
news:861e188290e72d5d9e04e862212c4684$1@www.eclipse.org...
> Hello,
> package testtptp;
> public static void main(String[] args) {
> aaa.doSomething();
> Code :
> package testtptp;
> public class Aaa {
> private int i = 0;
> public Aaa() {
> setI(getI() + 1);
> bbb.doOtherThing();
> this.i = i;
> return i;
> Code :
> package testtptp;
> public class Bbb {
> private int d=15;
> setD(getD() + 1);
> this.d = d;
> return d;
> Trace File:
> Start.java main
> Aaa.java Aaa()
> Aaa.java GetI()
> Aaa.java SetI()
> BBB.java GetD()
> BBB.java SetD()
> Pierre8r
Re: How to trace with TPTP ? [message #141585 is a reply to message #141412] Tue, 31 March 2009 13:08 Go to previous message
From
http://www.eclipse.org/tptp/monitoring/documents/tutorials/t ptp_btm_setup_4.5.html#1.2
The CBE part of BtM has dependency on LTA (Log and Trace Analyzer) which
is moved out from TPTP main release. If you want to use CBE part, please
have LTA installed firstly. We'll disable CBE part when LTA is not
installed. https://bugs.eclipse.org/bugs/show_bug.cgi?id=237589
Previous Topic:tptp multiple client connect
Next Topic:"Run As > JUnit Test" on inherited test method
Current Time: Sat Jul 26 19:24:07 EDT 2025
Powered by FUDForum. Page generated in 0.26122 seconds
