Home » Archived » BIRT » BIRT Viewer Error
BIRT Viewer Error [message #1413788] Fri, 29 August 2014 08:24 Go to next message
i'm trying to update the birt viewer in my server but getting an error.
The error is this:
java.lang.NoSuchMethodError: org.eclipse.birt.report.engine.api.EmitterInfo.<init>(Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/String;Ljava/lang/Boolean;Ljava/lang/Boolean;Lorg/eclipse/birt/core/framework/IConfigurationElement;)V
at org.eclipse.birt.report.engine.extension.internal.ExtensionManager.loadEmitterExtensionDefns(ExtensionManager.java:593)
at org.eclipse.birt.report.engine.extension.internal.ExtensionManager.<init>(ExtensionManager.java:142)
at org.eclipse.birt.report.engine.extension.internal.ExtensionManager.createInstance(ExtensionManager.java:155)
at org.eclipse.birt.report.engine.extension.internal.ExtensionManager.getInstance(ExtensionManager.java:164)
at org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.<init>(ReportEngineHelper.java:79)
at org.eclipse.birt.report.engine.api.impl.ReportEngine.<init>(ReportEngine.java:127)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$1.run(ReportEngineFactory.java:18)
at org.eclipse.birt.report.engine.api.impl.ReportEngineFactory$1.run(ReportEngineFactory.java:1)
My server is jboss, and this is how i tried:
I was using 2.3.2 version, and trying to update to 2.5.0
1)Downloaded the runtime from birt site;
2)Pasted where the old folder is;
3) Change the configuration archive of jboss with this line:
#report.engine.home=C:/user/dts-0/ServidorAplicacao/birt-runtime-2_3_2/ReportEngine
report.engine.home=C:/user/dts-0/ServidorAplicacao/birt-runtime-2_5_0/ReportEngine
4) tried: localhost:8080/birt and shows the page saying that the birt version is installed. But when i try to open a report it shows blank. And when i tried to generate a rptdesign of mine, it shows the error i pointed in the beginning of the topic.
I read in somewhere that if you want to upgrade birt, you have to upgrade mannualy some plugins. But where?
[Updated on: Fri, 29 August 2014 09:04] by Moderator
Re: BIRT Viewer Error [message #1415980 is a reply to message #1413788] Thu, 04 September 2014 01:00 Go to previous message
You replaced the current viewer in JBoss with the new WebViewerExample and it tells you the 2.5.0 viewer is installed? Does the test report run?
Previous Topic:How to find out page breaks using birt api
Next Topic:How to calculate percentage in the same column?
Current Time: Sat Jul 26 22:27:09 EDT 2025
Powered by FUDForum. Page generated in 0.04950 seconds
