Re: Identifying the DSL editor in Jubula [message #1413738 is a reply to message #1413723] |
Fri, 29 August 2014 05:55  |
Hi Deepa,
If the editor is not yet recognized in the object mapping mode, then you could write an extension that recognizes it. There's information on doing that in the Extension Manual, and if you get stuck then you can send a mail to the rc-dev list. At the moment it's not supported out of the box, but if you do write an extension for it, then we'd be happy to review a patch.
Depending on what you want to do within the editor, you could simply make the editor mappable so that you can perform replace text, check text etc. If you want to do actions such as entering text at specific places, then you might also need some actions to click at a certain text position in the editor and then enter the text.
For now, a workaround is probably to click in the editor using "click in active window" and to use "application input text" to enter your text. Again though, it will depend on what exactly you want to to.
Alex
FUDForum. Page generated in 0.28485 seconds
