Home » Eclipse Projects » Sirius » Large Model Support(About Large Model support)
Large Model Support [message #1413637] Thu, 28 August 2014 23:21 Go to next message
I have a large model, about 100M. Sirius load this model requires about an hour. Is there any suggestion?
Re: Large Model Support [message #1413659 is a reply to message #1413637] Fri, 29 August 2014 01:09 Go to previous messageGo to next message
Using the EMF's reflective editor, only need to spend 1 minutes to open this model.
Re: Large Model Support [message #1413706 is a reply to message #1413659] Fri, 29 August 2014 04:27 Go to previous message
> this model.
How do you try to load you model with Sirius ? Do you convert an
existing project into a modeling project or do you drag and drop you
model in a modeling project ? Could you try in a standard project to
right clic you model and create a new representation file (the different
action will be available on the aird file instead of on the project).
Which Viewppoint Specification Model do you use ? Could you check that
the "Initialization" attribute of you representation descriptions is
disabled. If enabled, Sirius will look for all representations to create
when a Viewpoint is activated for the first time.
Maxime - Obeo
Need professional services for Sirius?
Previous Topic: Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug-in
Next Topic:Custom XML model editor
Current Time: Sat Jul 26 11:51:48 EDT 2025
Powered by FUDForum. Page generated in 0.06402 seconds
