Home » Language IDEs » C / C++ IDE (CDT) » the automatically generated makefile(how to read the generated makefile)
the automatically generated makefile [message #1412604] Tue, 26 August 2014 11:12 Go to next message
I'm doing some exotic linking and compiling with libraries and such in my experiment.
I've used the project configuration where the makefile is automatically written by CDT or something. I've got it to compile a bit but I need to see how it links all the libs from Qt to understand this further.
How can I read the makefile that the Eclipse IDE creates. Where is it?
my code :
// Name        : Sf1.cpp
// Author      :
// Version     :
// Copyright   : Your copyright notice
// Description : Hello World in C++, Ansi-style
#include <iostream>
#include "SfWin.h"
int main() {
	SfWin w;
	w.show();
	return 0;
 * SfWin.h
 *  Created on: 26.08.2014
 *      Author: David
#ifndef SFWIN_H_
#define SFWIN_H_
#include <QWidget>
class SfWin : public QWidget {
//	Q_OBJECT
public:
	SfWin();
	virtual ~SfWin();
	void show();
#endif /* SFWIN_H_ */
 * SfWin.cpp
 *      Author:
#include <iostream>
#include "SfWin.h"
using namespace std;
SfWin::SfWin() {
	// TODO Auto-generated constructor stub
SfWin::~SfWin() {
	// TODO Auto-generated destructor stub
void SfWin::show() {
	std::cout << "SfWin.show()" << std::endl;
Re: the automatically generated makefile [message #1412637 is a reply to message #1412604] Tue, 26 August 2014 13:12 Go to previous messageGo to next message
Moving this to the CDT forum group.
Re: the automatically generated makefile [message #1412682 is a reply to message #1412604] Tue, 26 August 2014 16:29 Go to previous messageGo to next message
David Hall wrote on Tue, 26 August 2014 18:12
The makefile is in the build configuration subdirectory
(usually Release or Debug). It is named 'makefile', and it
includes some auxiliary makefiles (*.mk).
The makefiles are explained in the GNU Make manual, which
is available from the GNU software website (The forum did
not allow to post a link, sorry).
Re: the automatically generated makefile [message #1412707 is a reply to message #1412682] Tue, 26 August 2014 18:04 Go to previous messageGo to next message
This is Eclipse Luna 4.4.0
I created a project 'Ab' using File/New/C-C++ Project/Hello World C++ Project
and a source directory is created as well as a .cproject and .project file.
Under src directory is Ab.cpp where the main() lies.
No makefile.
after a Debug build there is a Debug directory with an exe file and a src directory where
the object file lies. The same happens with a Release build.
No makefile.
Nothing with an extension of ".mk"
Re: the automatically generated makefile [message #1412859 is a reply to message #1412707] Wed, 27 August 2014 04:43 Go to previous messageGo to next message
I had to create a fresh C project for hello to check (Luna 4.4.0, 20140612-0600).
Here is the Eclipse window before first build:
index.php/fa/18948/0/
Here is the Eclipse window after first debug build:
index.php/fa/18947/0/ Attached are two screen captures:
I just wonder if your setup has some settings gone fishy.
Re: the automatically generated makefile [message #1412861 is a reply to message #1412859] Wed, 27 August 2014 04:44 Go to previous messageGo to next message
Sorry, the forum switched the images, please regard as built image first.
Re: the automatically generated makefile [message #1412884 is a reply to message #1412861] Wed, 27 August 2014 05:33 Go to previous messageGo to next message
Very interesting Tauno.
Here is a shot of my C++ project, after build.
Where can I see a summary of all my preferences? In some kind of .project file??
index.php/fa/18950/0/
Re: the automatically generated makefile [message #1412886 is a reply to message #1412884] Wed, 27 August 2014 05:39 Go to previous messageGo to next message
I tried to create a C Hello World project named "Test", just like yours.
This is what I got :
index.php/fa/18951/0/
Re: the automatically generated makefile [message #1412889 is a reply to message #1412884] Wed, 27 August 2014 05:47 Go to previous messageGo to next message
The workspace preferences are found in Window -> Preferences (Eclipse -> Preferences in OS X).
The project preferences are in Project -> Properties.
It seems to me that you're using cmake instead of GNU make. Out of curiosity, have a look at the cmake subdirectory.
Re: the automatically generated makefile [message #1412901 is a reply to message #1412604] Wed, 27 August 2014 06:23 Go to previous messageGo to next message
Hello David,
you must select the "External builder" type to get the makefiles in the project settings:
http://help.eclipse.org/luna/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Ftasks%2Fcdt_t_proj_build_set.htm
But to learn make you better should read the make manual:
http://www.gnu.org/software/make/manual/make.html#Introduction
regards,
Klaus
Re: the automatically generated makefile [message #1412990 is a reply to message #1412889] Wed, 27 August 2014 10:13 Go to previous messageGo to next message
Thanks Tauno
That whole CMake folder got sucked into the project when I imported the many, many library files from Qt/../lib. I only know a bit about working with MAKE, not CMAKE, XMAKE, YMAKE, or not even QMAKE.
I'll check out those preferences Mr. Klaus, thanks.
Re: the automatically generated makefile [message #1413009 is a reply to message #1412901] Wed, 27 August 2014 10:57 Go to previous messageGo to next message
Mr. Klaus I have looked up the links you showed.
As is often the case the help file image you gave the link to
has only a vague similarity to reality.
I am working with Eclipse Luna 4.4.0
This is the menu I have when I select properties from the context menu of my project and select C/C++ Build on the left-hand tree.
In this menu under the tab Builder Settings is the textfield Builder Type. !! It is blocked from entering anything. The two other tabs I have, 'Behaviour' and 'Refresh Policy' are not depicted in the help file image.
It has Internal Builder and no other options.
index.php/fa/18963/0/
The second screen shot is from C/C++ Build/Settings on the left-hand tree.
Here nothing resembles 'Builder Type'
index.php/fa/18964/0/
Re: the automatically generated makefile [message #1413046 is a reply to message #1413009] Wed, 27 August 2014 12:28 Go to previous messageGo to next message
Now I find that the only way to have a generated makefile visible is to create a "Makefile Project"
All this time I have been creating an "Executable" project.
So Executable projects don't use makefiles. Is that the way this is??
Re: the automatically generated makefile [message #1413110 is a reply to message #1413046] Wed, 27 August 2014 16:39 Go to previous messageGo to next message
David Hall wrote on Wed, 27 August 2014 18:28
You can use "Executable project", but then you must switch the "Current builder" within the properties once (and therefore i forgot that...).
index.php/fa/18980/0/
After changing the setting to "Gnu Make Builder" you can go back to the other dialog and switch the setting between internal and external builder.
Do not ask me why this is necessary, i don't know. CDT settings are tricky Crying or Very Sad
regards
  • Attachment: eclipse.PNG
    (Size: 27.60KB, Downloaded 1842 times)
Re: the automatically generated makefile [message #1413258 is a reply to message #1413046] Thu, 28 August 2014 03:05 Go to previous messageGo to next message
Hello David,
I'm a bit slow - it seems that you are attempting to cut corners compiling a Qt application. The Qt qmake creates the necessary makefiles.
Eclipse has a Qt support module which is installable using the Luna site.
Re: the automatically generated makefile [message #1413306 is a reply to message #1413258] Thu, 28 August 2014 04:47 Go to previous messageGo to next message
If cutting corners means trying to find out how something works then you are right on the button.
I want to learn how to use eclipse and one way is to transform my monstrous SpaceFlight project from Java to C++. For that I need to learn how Eclipse does GUI. And I am starting with Qt library QWidgets. True, I could use the Qt Creator IDE to do this, but I would like to finally understand this behemoth Eclipse.
If this Qt Support Module really exists, possibly you could put up a link.
[Updated on: Thu, 28 August 2014 04:58] by Moderator
Re: the automatically generated makefile [message #1413308 is a reply to message #1413306] Thu, 28 August 2014 04:50 Go to previous messageGo to next message
Mr. Klaus, ausgezeichnet.
You solved it for me.
Re: the automatically generated makefile [message #1413809 is a reply to message #1413306] Fri, 29 August 2014 09:22 Go to previous message
David Hall wrote on Thu, 28 August 2014 11:47
Open your Luna, Help -> Install New Software, select Luna site (download.eclipse.org/releases/luna), Programming Languages -> C/C++ Qt Support.
Previous Topic:Custom Tool Chain for IBM Visual Age C/C++
Next Topic:Opening .exe instead of eclipse console
Current Time: Fri Nov 07 20:55:48 EST 2025
Powered by FUDForum. Page generated in 0.05740 seconds
