Compare with previous revision [message #1412062] |
Mon, 25 August 2014 03:48  |
Hi Olivier,
often I have a model under a version control system, git or you know..
clearcase. Do you know what would be needed in order to integrate emf
diff/merge into the "Compare with previous revision" operations of the
git/clearcase scm providers? This would be an awesome feature, I might
even be interested in helping out here.
Felix
Re: Compare with previous revision [message #1412501 is a reply to message #1412485] |
Tue, 26 August 2014 06:01  |
On 26/08/2014 11:25, Olivier Constant wrote:
> Hi Felix,
> I guess that requires some work on a deeper integration of EMF
> Diff/Merge with the Eclipse Team framework.
> http://www.eclipse.org/eclipse/platform-team/
> I assume that would work for EGit. I am unsure about Clearcase, unless
> you have Clearcase integration plugins for Eclipse that use the Team
> API. Otherwise, you would have to integrate with Clearcase at low level
> or via Clearcase-specific integration API.
Mhm, okay, we'll have to see about clearcase. I thought that maybe
Clearcase also connects to the team framework so that support for model
comparisons is maybe independent on the actual scm version used.
I could also look at how "Compare with local history..." works and see
if there's a possibility to connect this to Diff/Merge.
FUDForum. Page generated in 0.03675 seconds
