Home » Eclipse Projects » Sirius » Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug-in
Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug-in [message #1409296] Sun, 17 August 2014 14:33 Go to next message
Hi all,
First, I would like to thank OBEO team for such a great tool.
I'm using Sirius to create a designer for IFML language using the IFML metamodel. Source code available here github.com/ifml/ifml-editor.
Everything is working fine in development mode, but when I build the plugin and install it for the update site, the queries from my mtl file are not working.
My file is registered as a java extension using the Acceleo syntax (com::exemple::helper), I have the dependency org.eclipse.sirius.common.acceleo.mtl and my project has the Accleo nature.
Is there something else I need to do to get it to work?
NB. I'm working with eclipse Luna
Thank you
Re: Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug [message #1409603 is a reply to message #1409296] Mon, 18 August 2014 10:15 Go to previous messageGo to next message
Le 18/08/2014 15:22, Hamza Ed-douibi a écrit :
> Hi all,
Thanks for your feedback!
> are not working. My file is registered as a java extension using the
> nature. Is there something else I need to do to get it to work?
Can you check that you have etml files in your plugin from your update
site? The *.emtl files are the binary/compiled files of *.mtl files
(like *.class files for *.java files). If these files do not exist in
your deployable plugin there is a problem in your build process.
That's my first idea.
> Thank you
Laurent - Obeo
Need professional services for Sirius?
Re: Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug [message #1409612 is a reply to message #1409296] Mon, 18 August 2014 10:31 Go to previous messageGo to next message
Hamza, you also have a simple example in previous post:
https://www.eclipse.org/forums/index.php/mv/msg/797227/1405932/#msg_1405932
Laurent - Obeo
> Hi all,
> Thank you
Re: Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug [message #1409629 is a reply to message #1409603] Mon, 18 August 2014 11:18 Go to previous messageGo to next message
Hi Laurent,
Thank you for your answer. I have just checked the existence of the .emtl file, it's there under the name helper.emtl in the same folder as helper.mtl.
Is this mean that my plugin is built correctly?
I have already checked the example you mentioned before posting my question, I'm following the same instructions.
Thank you again.
Re: Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug [message #1412220 is a reply to message #1409629] Mon, 25 August 2014 11:32 Go to previous messageGo to next message
Hi all,
I managed to fix the issue by removing org.eclipse.core.resources from the dependencies of the designer plugin. This was creating a confusion for Acceleo because because this dependency it already reexported from our emf metamodel editor project and this redundancy prevented Acceleo from using this library to select the resource requested in the queries. Somehow this was tolerated in the development mode but not after building the plugin.
Cheers
Hamza
Re: Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug [message #1412230 is a reply to message #1409629] Mon, 25 August 2014 12:03 Go to previous messageGo to next message
To use mtl files in sirius you should first build them with tycho.
You can find an example here:http://wiki.eclipse.org/Acceleo/Maven
Here you can see an example of the configuration of the build for an Acceleo generator: http://git.eclipse.org/c/m2t/org.eclipse.acceleo.git/tree/tests/org.eclipse.acceleo.maven.tests/pom.xml
Re: Acceleo queries defined in the .mtl files are not working when the project is deployed as a plug [message #1413501 is a reply to message #1412230] Thu, 28 August 2014 13:35 Go to previous message
Thank you Julien for the tips.
Previous Topic:Unable to set a viewpoint based on table on existing project
Next Topic:Large Model Support
Current Time: Thu Jul 24 21:53:00 EDT 2025
Powered by FUDForum. Page generated in 0.07053 seconds
