Home » Eclipse Projects » e(fx)clipse » Canvas is not a valid type(Cannot integrate JavaFx Canvas into efxclipse application)
Canvas is not a valid type [message #1411858] Sun, 24 August 2014 13:07 Go to next message
Eclipse GuestFriend
Member
I can run efxclipse applications and I already tried out several different containers and controls within the fxml file. I create the UI content via InjectingFXMLLoader.create(...). Unfortunately, when adding a simple Canvas to the fxml file, I get the error "javafx.fxml.LoadException: Canvas is not a valid type.".
Is the JavaFx Canvas not yet supported by efxclipse or did I miss something important?
Any ideas?
I am running the standard "all-in-one" eclipse SDK download from the efxclipse homepage (Luna 4.4, Build id: I20140606-1215).
[Updated on: Mon, 25 August 2014 02:30]
Re: Canvas is not a valid type [message #1412145 is a reply to message #1411858] Mon, 25 August 2014 08:04 Go to previous messageGo to next message
There's nothing that needs to be ported to e(fx)clipse, when you launch
your application pure java/javafx is running. So there must be a problem
in your FXML/application code.
Tom
On 24.08.14 19:07, Michael Marton wrote:
> Hi
> different containers and controls but when trying to integrate a simple
> Canvas into a fxml file, I get the error "javafx.fxml.LoadException:
> Canvas is not a valid type.". Is the JavaFx Canvas not yet ported to
> Any ideas?
> best regards
> Michael
Re: Canvas is not a valid type [message #1412186 is a reply to message #1412145] Mon, 25 August 2014 10:00 Go to previous messageGo to next message
Eclipse GuestFriend
Member
Ok, then this was a misunderstanding from my side but still the JavaFx Canvas is not recognized.
- I downloaded the newest "eclipse SDK 4.4 1.0.0 SNAPSHOT", created a new workspace and a sample
"e4 Media Application": works fine
- I added an additional Part in the Application.e4xmi, created an additional fxml file and assigned a new part class to it
which loads the fxml file via "InjectingFXMLLoader.create(...)": works fine
this is the content of the working fxml:
<?import java.lang.*?>
<?import javafx.scene.control.*?>
<?import javafx.scene.layout.*?>
<BorderPane xmlns:fx="[url]http://javafx.com/fxml/1[/url]" xmlns="[url]http://javafx.com/javafx/8[/url]">
	<center>
		<Pane prefHeight="200.0" prefWidth="200.0" BorderPane.alignment="CENTER">
			<children>
				<Button layoutX="74.0" layoutY="14.0" mnemonicParsing="false" text="Button" />
			</children>
		</Pane>
	</center>
</BorderPane>
- then I added a Canvas to the fxml file and on startup a LoadException is thrown("Canvas is not a valid type")
this is the content of the non-working fxml:
<?import javafx.scene.canvas.*?>
<BorderPane xmlns="[url]http://javafx.com/javafx/8[/url]" xmlns:fx="[url]http://javafx.com/fxml/1[/url]">
	<center>
			<children>
				<Canvas height="200.0" width="200.0" />
			</children>
		</Pane>
	</center>
</BorderPane>
...and this is the code for loading the fxml
public class MyPart {
	@Inject
	private MPart part;
	private Node focusNode;
	@PostConstruct
	void init(BorderPane p) {
        InjectingFXMLLoader<Object> fxmlLoader = InjectingFXMLLoader.create(part.getContext(), getClass(), "MyPart.fxml");
        Node node = null;
        try {
            node = (Node) fxmlLoader.load();
            if(node != null) {
                p.setCenter(node);
                focusNode = node;
        } catch (IOException exception) {
            exception.printStackTrace();
Any ideas what could be wrong?
best regards
Michael
[Updated on: Mon, 25 August 2014 10:11]
Re: Canvas is not a valid type [message #1412190 is a reply to message #1412186] Mon, 25 August 2014 10:11 Go to previous messageGo to next message
Please check your package-imports in the MANIFEST.MF? Is the package
javafx.scene.canvas imported?
Tom
> new workspace and a sample "e4 Media Application": works fine
> additional fxml file and assigned a new part class to it which loads the
> <BorderPane xmlns:fx="http://javafx.com/fxml/1"
> xmlns="http://javafx.com/javafx/8">
> <center>
> <children>
> </children>
> </Pane>
> </center>
> </BorderPane>
> <BorderPane xmlns="http://javafx.com/javafx/8"
> xmlns:fx="http://javafx.com/fxml/1">
> <center>
> <children>
> </children>
> </Pane>
> </center>
> </BorderPane>
Re: Canvas is not a valid type [message #1412201 is a reply to message #1412190] Mon, 25 August 2014 10:37 Go to previous message
Eclipse GuestFriend
Member
apparently, the dependency to "javafx.scene.canvas" was the only one missing
from the "javafx.scene" package Sad
...added it and it works fine now.
have to look a little bit closer in future
thanks for your help
[Updated on: Mon, 25 August 2014 10:41]
Previous Topic:Embedding JavaFX in SWT E4 RCP application doesn't work
Next Topic:CleanUpAddon and DndAddon
Current Time: Sun Jul 20 23:38:41 EDT 2025
Powered by FUDForum. Page generated in 0.29728 seconds
