Home » Modeling » TMF (Xtext) » [SOLVED] Serializer Enum
[SOLVED] Serializer Enum [message #1411842] Sun, 24 August 2014 11:57 Go to next message
Hi!
I've got a problem regarding the usage of enums.
Here's a part of my used grammar:
// boolAndExpr -> boolOrExpr (andoperation boolOrExpr)*
boolAndExpr returns BooleanExpression:
	boolOrExpr ({BooleanOperatorExpression.left=current} operation=andoperation right=boolOrExpr)*
// andoperation -> AND
enum andoperation returns BooleanOperations:
	AND
// boolOrExpr -> compareExpr (oroperations compareExpr)*
boolOrExpr returns BooleanExpression:
	compareExpr ({BooleanOperatorExpression.left=current} operation=oroperations right=compareExpr)*
// oroperations -> OR|XOR
enum oroperations returns BooleanOperations:
	OR | XOR
Parsing works pretty good, but when it comes to serializing something containing an AND this Exception comes up:
The value 'AND' is invalid for enum oroperations
Valid values are: OR, XOR
Semantic Object: BooleanOperatorExpression
I think it could be easily changed by changing the model and split up AND- and OR-Operations into two classes. But as it is a running system to which I only add the Xtext-things, I do not want to change the model that much... So any idea how to solve this?
Thanks in advance for any hints!
Jonas
[Updated on: Sun, 24 August 2014 14:18] by Moderator
Re: Serializer Enum [message #1411854 is a reply to message #1411842] Sun, 24 August 2014 12:50 Go to previous messageGo to next message
i thinks the problem is how you missuse the enum
its actual declaration should be
enum BooleanOperations:
AND | OR | XOR
Re: Serializer Enum [message #1411859 is a reply to message #1411854] Sun, 24 August 2014 13:08 Go to previous messageGo to next message
Hi!
Thanks for the quick response!
I actually know how to do that, but as you may have noticed the Enum is split into two parts ([X]OR and AND) and AND should be only available in the boolAndExpr-rule while the others should be only available in the boolOrExpr-rule. This is to preserve precedence to be able to express things like "x OR y AND z OR p AND f" without using paranthesis or something...
Best regards
Jonas
Re: Serializer Enum [message #1411870 is a reply to message #1411859] Sun, 24 August 2014 13:46 Go to previous messageGo to next message
the question is what happens if you write a third rule that is never called but has all options
icon14.gif  Re: Serializer Enum [message #1411877 is a reply to message #1411870] Sun, 24 August 2014 14:18 Go to previous message
Hi!
Thanks a lot!
This works great:
//BooleanExpression -> boolOrExpr (BooleanOperations boolOrExpr)*
// Note: This is a workaround for the serializer to work with AND-Operations!
BooleanExpression:
	boolOrExpr ({BooleanOperatorExpression.left=current} operation=BooleanOperations right=boolOrExpr)*
//BooleanOperations -> AND | OR | XOR
	AND | OR | XOR
	AND
	OR | XOR
Best regards
Jonas
[Updated on: Sun, 24 August 2014 14:19] by Moderator
Previous Topic:[Xbase] Scripting Language
Next Topic:Xtext and generating JPA annotations
Current Time: Sat Jul 26 00:29:42 EDT 2025
Powered by FUDForum. Page generated in 0.03596 seconds
