Home » Eclipse Projects » Eclipse 4 » visibleWhen and core expressions
visibleWhen and core expressions [message #1409997] Tue, 19 August 2014 10:20 Go to next message
Hi, I have a problem making a command visible only when certain part is active. I have taken this approach
http://www.eclipse.org/forums/index.php/t/452233/
however, it seems that the core expression only gets evaluated at startup. When I change the context variable by calling context.set or even context.modify, the state of the command does not get updated. The almighty Lars Vogel, taking the same approach in his tutorial
http://www.vogella.com/tutorials/EclipseRCP/article.html#commandsmore_coreexpressionsown,
does not seem to face such an issue. How come?
Are core expressions supposed to get re-evaluted when the DI context changes? If not, how can I force re-evaluation? I know there is a method IEvaluationService.requestEvaluation but I couldn't obtain instance of the IEvaluationService through dependency injection. Should I obtain it by some 3.x way? Does not the e4 have some new and more fancy ways of handling the evaluation of core expressions?
Thanks.
[Updated on: Tue, 19 August 2014 10:22] by Moderator
Re: visibleWhen and core expressions [message #1411039 is a reply to message #1409997] Fri, 22 August 2014 04:35 Go to previous messageGo to next message
Hi guyes, I am getting a little bit frustrated about this issue. I like the new Eclipse 4 concept, but after 4 releases it still seems rather immature. Or its just my feeling caused by lack of any useful documentation.
Is there more appropriate place to ask such a question where the actual developers of the e4 might answer it? Problems with e4 are slowly piling up and I feel like returning to good old 3.x to save me some hair on my head.
[Updated on: Fri, 22 August 2014 04:36] by Moderator
Re: visibleWhen and core expressions [message #1412093 is a reply to message #1411039] Mon, 25 August 2014 05:21 Go to previous messageGo to next message
Sounds like you ran into the following issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=400217
Re: visibleWhen and core expressions [message #1413718 is a reply to message #1412093] Fri, 29 August 2014 05:02 Go to previous message
Hi Dirk,
thank you for your answer. I was aware of this bug but did not read it cerafully enough. Well, I have found that core-expressions are just not getting updated when you change a variable in IEclipseContext. I have found how to force the re-evaluation of expressions using the ExpressionsContext. However, even if the visibility is set, the MenuItems do not react on it. I have to manually dig in the SWT MenuRenderer and refresh it myself. I have written my own addon which does that. However, things got even more complicated after that and after whole day of investigenting this issue I decided to give up. I am returning to 3.x.
Previous Topic:[SOLVED] RCP: Part stack is removed when last part was closed
Next Topic:Referencing shared elements in different fragments
Current Time: Sun Jul 27 15:31:22 EDT 2025
Powered by FUDForum. Page generated in 0.04064 seconds
