IWAT0005E The host localhost was not found.? [message #141017] |
Fri, 06 March 2009 05:02  |
I completed the AGR setup and tried to run this through an ANT script.
testing the AGR inside Eclipse works fine in quick and standard mode. When
using it in an ant script i get this very weird error:
output from ant script:
Buildfile: F:\workspace001\se.rsv.eclipse.testing\test.xml
platform-verification:
[echo] Verifying connection...
[condition] Verification started!
[condition] Verifying connection:
[condition] {connectionString=tptp:rac://localhost:10002/default,
specification=tptp, serverClass=rac, host=localhost, port=10002,
serverInstance=/default, user=null, password=null}
[condition] The specified agent controller
'tptp:rac://localhost:10002/default' is up and running!
[condition] Verification completed!
test-execution:
[tptp:execution] Adding file
"F:\workspace001\se.rsv.eclipse.testing\Testsuite.testsuite".
[tptp:execution] Test execution started.
[tptp:execution] Test 'Testsuite.testsuite' started.
[tptp:execution] Preparing launch delegate...
[tptp:execution] Performing pre-launch check...
[tptp:execution] Performing final launch validation...
[tptp:execution] Initializing source locator...
[tptp:execution] Launching delegate...
[tptp:execution] org.eclipse.core.runtime.CoreException: IWAT4039E The
Test Execution Harness reported the following problems: IWAT0005E The host
[tptp:execution] at
org.eclipse.hyades.test.core.launch.delegates.AbstractLaunch ConfigurationDelegate2.launch(AbstractLaunchConfigurationDel egate2.java:225)
[tptp:execution] at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
[tptp:execution] at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
[tptp:execution] at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:607)
[tptp:execution] at
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.launch(AbstractTestExecutionService.java:822)
[tptp:execution] at
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.execute(AbstractTestExecutionService.java:592)
[tptp:execution] at
org.eclipse.hyades.automation.server.AbstractService.execute (AbstractService.java:43)
[tptp:execution] at
org.eclipse.hyades.automation.server.ServiceProxy$1.run(Serv iceProxy.java:139)
[tptp:execution] at
org.eclipse.hyades.automation.core.utils.ReusableThread.run( ReusableThread.java:131)
[tptp:execution] at java.lang.Thread.run(Unknown Source)
anyone have a clue what can cause this? as i do try to use localhost as an
condition before the test is started!
Re: IWAT0005E The host localhost was not found.? [message #141028 is a reply to message #141017] |
Fri, 06 March 2009 06:19   |
Hi David,
What version of TPTP? Are you using the Intergrated Agent Controller or
Agent Controller? Is there a firewall on your local machine?
If using an earlier version than TPTP 4.5, you may be running into:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=221278
Paul
"David " <david.samuelsson@skatteverket.se> wrote in message
news:ccbdbcfabebbcfc4af70e68f2effaf7c$1@www.eclipse.org...
> test-execution:
> [tptp:execution] at
> [tptp:execution] at
> [tptp:execution] at
> [tptp:execution] at
> [tptp:execution] at
> [tptp:execution] at
> [tptp:execution] at
> [tptp:execution] at
> [tptp:execution] at
Re: IWAT0005E The host localhost was not found.? [message #141106 is a reply to message #141039] |
Mon, 09 March 2009 06:24  |
Hi David,
Assuming your paths are correct (e.g.
F:\workspace001\se.rsv.eclipse.testing\), this symptom appears to be a new
defect. Please open a TPTP Bugzilla against the TPTP ASF product and
ASF.Runtime component. Can you try running a sample TPTP JUnit test suite
(e.g. see
/org.eclipse.hyades.test.core.services.tests/resources/Ant/b uild.xml) and
report the results in the defect?
Paul
news:95763899ff513bb7a716cee3890b0ec1$1@www.eclipse.org...
> TPTP platform 4.5.2
> I have not installed any additional agent controllers so its the
> integrated.
> I have an firewall on the machine, tested disabling the services and tried
> to rerun with the same result. I was using the "suite" command but had
> problems with it and used the "fileset" instead which made me go further
> but ran into other probs instead.
> ant script---- snipp
> <project name="se.rsv.eclipse.testing" default="main"
> xmlns:tptp="antlib:org.eclipse.hyades.automation.client.adapters.ant ">
> <!-- Global configuration: -->
> <property name="ECLIPSE_HOME" value="C:\temp\eclipse"/>
> <property name="ECLIPSE_WORKSPACE_HOME" value="F:\workspace001"/>
> <!-- Requirements:
> 1) Add the following dependencies to the Ant classpath or lib directory
> before running:
> -${tptp.automation.eclipse}\plugins\org.eclipse.hyades.execu tion_ <version>\ant-tptp.jar
> 2) Set the above global configuration.
> <!-- Define common properties for all automatable services -->
> <property name="tptp.automation.eclipse" value="${ECLIPSE_HOME}"/>
> <property name="tptp.test.workspace" value="${ECLIPSE_WORKSPACE_HOME}"/>
> <property name="tptp.test.project" value="se.rsv.eclipse.testing" />
> <property name="tptp.test.connection"
> value="tptp:rac://localhost:10002/default"/>
> <property name="project.dir"
> value="${tptp.test.workspace}\${tptp.test.project}" />
> <!-- Define script-local properties, that vary by installation -->
> <!-- <property name="project.dir"
> value="${tptp.test.workspace}\${tptp.test.project}" /> -->
> <!-- process start -->
> <target name="main" depends="platform-verification, test-execution" />
> <!-- Verify agent controller availability using condition task -->
> <target name="platform-verification">
> <echo message="Verifying connection..." /> <condition
> property="tptp.platform.available">
> <tptp:verification />
> </condition>
> <fail unless="tptp.platform.available" message="The agent controller is
> not available using the specified connection string!!" />
> </target> <target name="test-execution" description="Executes:
> Sample*Test.testsuite">
> <tptp:execution resultsrefid="tptp.test.results"> <fileset
> dir="${project.dir}">
> <include name="*.testsuite"/>
> </fileset>
> </tptp:execution>
> </target>
> </project>
FUDForum. Page generated in 0.07393 seconds
