Home » Modeling » TMF (Xtext) » xtextbin
xtextbin [message #1409884] Tue, 19 August 2014 04:08 Go to next message
I have an xtext grammar, which I use in a standalone way, I get an
exception on processing the .xtextbin. The reason is that the
BinaryGrammarResourceFactory is not registered for this extension.
In another grammar, I see this in [grammar]StandAloneSetupGenerated:
if
(!Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().containsKey("xtextbin"))
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(
"xtextbin", new
org.eclipse.xtext.resource.impl.BinaryGrammarResourceFactoryImpl());
So, my question is, what would trigger this to be included, (Pressume in
the mwe2 definition?).
Oh, en what is xtextbin ?
Thank You,
Christophe
Re: xtextbin [message #1409890 is a reply to message #1409884] Tue, 19 August 2014 04:26 Go to previous messageGo to next message
xtextbin is (basically) a persisted version of the grammar
Re: xtextbin [message #1409896 is a reply to message #1409890] Tue, 19 August 2014 04:41 Go to previous messageGo to next message
On 19-08-14 10:26, Christian Dietrich wrote:
Thx Christian, do you know about my first question? What controls if the
registration of xtextbin resourcefactory happens?
Re: xtextbin [message #1409905 is a reply to message #1409896] Tue, 19 August 2014 05:10 Go to previous messageGo to next message
btw the trigger to exclude this is a xmlVersion In GrammarAccessFragment
Re: xtextbin [message #1409933 is a reply to message #1409884] Tue, 19 August 2014 06:39 Go to previous messageGo to next message
The registration is conditionally included by the lines you have quoted.
For the most past *.xtextbin just works, unless you try to backport to
Juno for which Xtext 2.3.0 had no *.xtextbin support.
If you want an Xtext 2.4/2.5/2.6 generated editor to work on Juno and
Xtext 2.3.0 have a look at
org.eclipse.ocl.examples.xtext.base.services.CompatibilityGrammarProvider.BinaryGrammarResourceFactoryImpl
and its references.
Ed Willink
On 19/08/2014 09:08, Christophe Bouhier wrote:
> if
> "xtextbin", new
> Thank You,
> Christophe
Re: xtextbin [message #1409969 is a reply to message #1409905] Tue, 19 August 2014 08:59 Go to previous messageGo to next message
Thanks, Now I also noticed, the .ecore and .genmodel wasn't generated...
Is this default behaviour?
Re: xtextbin [message #1409984 is a reply to message #1409969] Tue, 19 August 2014 09:36 Go to previous message
this is done by EcoreGeneratorFragment
Previous Topic:xtext 2.6 and org.eclipse.search
Next Topic:Grammar element with cross-reference
Current Time: Mon Jul 21 11:27:49 EDT 2025
Powered by FUDForum. Page generated in 0.07339 seconds
