Home » Modeling » MoDisco » How to load a Java model
How to load a Java model [message #1409886] Tue, 19 August 2014 04:13 Go to next message
Hello.
I just created a java model using a MoDisco Discoverer (Discover java project). I would like to load the corresponding xmi file in a java program so as to parse that java model. How can I load that xmi file using its full path i.e the full path of the java model?
Thanks in advance.
Re: How to load a Java model [message #1409917 is a reply to message #1409886] Tue, 19 August 2014 05:46 Go to previous messageGo to next message
When serialized in XMI, the Java model can be loaded as any EMF model using the standard EMF API or the Java metamodel-specific generated API.
Please, refer to the EMF documentation and/or forum in order to do so.
Re: How to load a Java model [message #1410010 is a reply to message #1409917] Tue, 19 August 2014 10:55 Go to previous message
Thank you for your reply. It really helped. In fact, I was able to write a code to load an EMF model. But I did not know the concepts of the Java metamodel and their relationships with JDT. As a consequence, I was stuck at the instruction allowing to get the first item of my resource's content, unable to make the right cast. Your explanation combined with the following link http://help.eclipse.org/luna/index.jsp?topic=%2Forg.eclipse.modisco.java.doc%2Fmediawiki%2Fjava_metamodel%2Fuser.html clarified the ideas in my head. Here is the code I finally wrote to load my model:
public Model loadJavaModel(String projectPath){
Model javaModel = null;
try{
// register the default resource factory
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("xmi",
new XMIResourceFactoryImpl());
// create a resource set.
ResourceSet resourceSet = new ResourceSetImpl();
//get the URI of the model file.
URI fileURI = URI.createFileURI(new File(projectPath).getAbsolutePath());
//load the resource for this file
Resource resourceModel = resourceSet.getResource(fileURI, true);
// get the root element of the javamodel's project
javaModel = (Model) resourceModel.getContents().get(0);
catch (Exception e) {
System.out.println("An error occurred. The model can not be loaded.");
//e.printStackTrace();
return javaModel;
Previous Topic:Custom discoverer
Next Topic:Developer Setup
Current Time: Fri Jun 06 00:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.25891 seconds
