Home » Modeling » EMF » DocumentRoot is generated in final XML
DocumentRoot is generated in final XML [message #1408655] Fri, 15 August 2014 13:58 Go to next message
I was working on my model and wrote substantial supporting code around it. After needed regen my XML contains DocumentRoot in it:
<rep:DocumentRoot xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:rep="http://repo.com/xml/repository">
  <rChannel description="" name="ww" targetServer="7.0.2-SNAPSHOT" uid="161FC3B35274C9963FA4DAD0574DF550"/>
</rep:DocumentRoot>
I am not sure what caused it, and I remember I fix this in the past, but don't remember what I did. I have different roots of the model created into separate files and all of them, including above mentioned channel element using the same code:
protected abstract EReference getModelEReference();
protected EObject createInitialModel(String guid) {
	EClass eClass = ExtendedMetaData.INSTANCE.getDocumentRoot(channelPackage);
	EStructuralFeature eStructuralFeature = eClass.getEStructuralFeature(getModelEReference().getName());
	EObject rootObject = channelFactory.create(eClass);
	rootObject.eSet(eStructuralFeature, EcoreUtil.create((EClass)eStructuralFeature.getEType()));
	EObject feature = (EObject) rootObject.eGet(eStructuralFeature);
	feature.eSet(ChannelPackage.eINSTANCE.getComponent_Name(), (String) model.get(AbstractIWResourceGeneralPropertiesPage.RESOURCE_NAME));
	feature.eSet(ChannelPackage.eINSTANCE.getComponent_Description(), (String) model.get(AbstractIWResourceGeneralPropertiesPage.RESOURCE_DESC));
	feature.eSet(ChannelPackage.eINSTANCE.getComponent_TargetServer(), (String) model.get(AbstractIWResourceGeneralPropertiesPage.RESOURCE_TARGET_VERSION));
	feature.eSet(ChannelPackage.eINSTANCE.getComponent_Uid(), guid);
	return rootObject;
I think it's something minor I overlooked. Any help is appreciated.
[Updated on: Fri, 15 August 2014 13:59] by Moderator
Re: DocumentRoot is generated in final XML [message #1408958 is a reply to message #1408655] Sat, 16 August 2014 12:33 Go to previous messageGo to next message
Serrizlization result depends on what resource implementation you're using, and not model itself is created. So, code with resource/resourceSet instantiation would be more uselful.
From what I see in you serrialized model - it's an XMI resource, not an XML. Chech resource instances you're using, and resource factory registrations (including file extensions).
Re: DocumentRoot is generated in final XML [message #1410072 is a reply to message #1408958] Tue, 19 August 2014 14:53 Go to previous message
Thanks Leonid,
I found the problem thanks to your hits. I was moving code around and somewhere down the line omitted org.eclipse.emf.ecore.extension_parser that maps file extension to resource factory. Once I defined it everything worked.
Previous Topic:CDO Timeout Exception
Next Topic:Hiding menu items from context menu of generated editor
Current Time: Thu Jul 24 23:17:08 EDT 2025
Powered by FUDForum. Page generated in 0.30742 seconds
