Home » Modeling » TMF (Xtext) » Xtext and generating JPA annotations(How to generate annotation in Xtext)
Xtext and generating JPA annotations [message #1264823] Wed, 05 March 2014 09:32 Go to next message
I want to change domainmodel example on the xtext website to generate annotations same as the example below, regarding to use the generated entity classes in the JPA application.
@Entity
@Table(name = 'USERS')
@NamedQuery(name='User.findUserByEmail', query='select u from User u where u.email = :email')
does anyone know?
Thanks in advance,
Mary
[Updated on: Wed, 05 March 2014 13:18] by Moderator
Re: Xtext and generating JPA annotations [message #1265179 is a reply to message #1264823] Wed, 05 March 2014 14:53 Go to previous messageGo to next message
i am not sure what your specific question is...
i asume you are using the domain model example that leverages xbase.
then you can simply* extend the jvmmodelinferrer like...
( i dont know your logic how to get the table name and finder....)
unfortunately the api for annotation values seem to suck a bit ....
def dispatch infer(Entity entity, IJvmDeclaredTypeAcceptor acceptor, boolean prelinkingPhase) {
		acceptor.accept(
			entity.toClass( entity.fullyQualifiedName )
		).initializeLater [
			annotations += entity.toAnnotation("javax.persistence.Entity")
			annotations += entity.toAnnotation("javax.persistence.Table", "name" -> entity.name.toUpperCase)
			annotations += entity.toAnnotation("javax.persistence.NamedQuery", "name" -> "User.findUserByEmail","query"->'select u from User u where u.email = :email')
	@Inject TypesFactory typesFactory
	def JvmAnnotationReference toAnnotation(EObject ctx, String typeName, Pair<String,String>... values) {
		val a = ctx.toAnnotation(typeName)
		for (v : values) {
			val t = typesFactory.createJvmStringAnnotationValue
			t.values.add(v.value)
			t.operation = a.annotation.members.filter(JvmOperation).filter[simpleName==v.key].head
			a.values += t
		a
Re: Xtext and generating JPA annotations [message #1265223 is a reply to message #1265179] Wed, 05 March 2014 15:54 Go to previous messageGo to next message
p.s: the jpa api jar has to be on the classpath of the project containing the dmodel files
Re: Xtext and generating JPA annotations [message #1265600 is a reply to message #1265223] Thu, 06 March 2014 04:53 Go to previous messageGo to next message
Thanks for your reply Smile
Actually when I added this part of code:
ere u.em[/size]ail = :email')[/size]
At my eclipse run-time eclipse I could just generate:
@Entity
@Table
but no @Table(name = 'USERS') & @NamedQuery(name='User.findUserByEmail', query='select u from User u where u.email = :email'!!!
Than added the second part of your code, I got an error! I think there is a problem with the t.operation part!
for (v : values) {
a.values += t
a
I attached the error I got, Also I should mention that instead of creating the java project at run-time eclipse, I have EJB project!
  • Attachment: error
    (Size: 28.42KB, Downloaded 244 times)
Re: Xtext and generating JPA annotations [message #1265632 is a reply to message #1265600] Thu, 06 March 2014 05:39 Go to previous messageGo to next message
which xtext version do you use
can you try to use a simple java project with jpa api on classpath
can you please share your complete code incl. example project...
Re: Xtext and generating JPA annotations [message #1265689 is a reply to message #1265632] Thu, 06 March 2014 07:29 Go to previous messageGo to next message
Thanks a lot for your quick reply Smile
I am using xtext-2.5.3
Yes, actually I started java project and try to create mydmodel files there, but I got error: Xtext validation
also when I added the second part of your code to the jmvModelInferre class, and start the run-time eclipse I got the error I sent you before.
I attached my complete code and also the screenshot of my java project!
Re: Xtext and generating JPA annotations [message #1265706 is a reply to message #1265689] Thu, 06 March 2014 07:58 Go to previous messageGo to next message
i will have a look tonight
Re: Xtext and generating JPA annotations [message #1265721 is a reply to message #1265706] Thu, 06 March 2014 08:18 Go to previous messageGo to next message
Thanks in advance for your time Smile
Re: Xtext and generating JPA annotations [message #1265742 is a reply to message #1265721] Thu, 06 March 2014 08:50 Go to previous messageGo to next message
it looks like the api changed between 2.5.0 and 2.5.3
i dont know why this is.
it now seems to be
a.explicitValues += t
Re: Xtext and generating JPA annotations [message #1265774 is a reply to message #1265742] Thu, 06 March 2014 09:40 Go to previous messageGo to next message
Hi Christian,
Thanks for your help. now it is working properly Smile
Re: Xtext and generating JPA annotations [message #1408226 is a reply to message #1265774] Thu, 14 August 2014 10:43 Go to previous messageGo to next message
I have similar issue (printscreen is in attachment).
I wrote next code:
acceptor.accept(entity.toClass(entity.fullyQualifiedName)).initializeLater [
annotations += entity.toAnnotation(javax.ejb.Stateful)
annotations += entity.toAnnotation(javax.ejb.Remote)
I would like to have java class like next code:
@Stateful
@Remote(MyClass2.class)
public class MyClass {
I have jboss-ejb-api_3.2_spec-1.0.0.Final.jar on classpath in my project (also, you can see it in printscreen)
Mary, how did you solve your problem?
Thanks in advance,
Marko
Re: Xtext and generating JPA annotations [message #1409214 is a reply to message #1408226] Sun, 17 August 2014 08:35 Go to previous messageGo to next message
I solved my issue, I wrote javax.ejb.Stateful with quotation marks as "javax.ejb.Stateful" but I now have another issue: next code isn't work, annotations += entity.toAnnotation("javax.ejb.Remote", "value" -> xjaf.server.agm.AgentI). It should look like: @Remote(AgentI.class).
Can someone help me?
Thanks in advance,
Marko
Re: Xtext and generating JPA annotations [message #1409220 is a reply to message #1409214] Sun, 17 August 2014 09:04 Go to previous messageGo to next message
have a look at JvmTypeAnnotationValue
Re: Xtext and generating JPA annotations [message #1411923 is a reply to message #1409220] Sun, 24 August 2014 17:54 Go to previous message
Thank you Christian for your suggestion. I solved my problem. Solution is:
@Inject TypeReferences typeReferences;
def JvmAnnotationReference toAnnotation(/* @Nullable */ EObject sourceElement, /* @Nullable */ String annotationTypeName, /* @Nullable */ Class<?> value) {
val result = typesFactory.createJvmAnnotationReference() as JvmAnnotationReference;
val jvmType = typeReferences.findDeclaredType(annotationTypeName, sourceElement) as JvmAnnotationType;
if (jvmType == null) {
throw new IllegalArgumentException("The type "+annotationTypeName +" is not on the classpath.");
if (!(jvmType instanceof JvmAnnotationType)) {
throw new IllegalArgumentException("The given class " + annotationTypeName + " is not an annotation type.");
result.setAnnotation(jvmType);
val type = typeReferences.findDeclaredType(value, sourceElement)
if (value != null) {
val annotationValue = typesFactory.createJvmTypeAnnotationValue() as JvmTypeAnnotationValue
annotationValue.getValues().add (typeReferences.createTypeRef(type));
result.getExplicitValues().add(annotationValue);
result;
annotations += entity.toAnnotation("javax.ejb.Remote", AgentI)
Previous Topic:[SOLVED] Serializer Enum
Next Topic:How to test NatTable using swtbot?
Current Time: Sun Jul 20 21:37:51 EDT 2025
Powered by FUDForum. Page generated in 0.28339 seconds
