Can't run .exe files from eclipse! [message #140686] |
Mon, 14 March 2005 17:03  |
Originally posted by: eeerr.dfdf.com
I have made the following code:
#include <stdio.h>
int main(void)
int minTemp = 0;
int maxTemp = 300;
int tempInterval = 20;
int fahr = maxTemp;
int celsius;
printf("Fahrenheit Celsius\n");
while(fahr >= minTemp) {
celsius = 5 * (fahr-32) / 9;
printf("%d\t\t%d\n", fahr, celsius);
fahr = fahr - tempInterval;
getchar();
return 0;
It compiles ok and I also get a .exe file where I specified the output. But
I cannot run that .exe file from eclipse when I chose run. The only way I
can run the file is by finding it in Windows Explorer and then double click
it.
How do I run the .exe I generate in Eclipse??
JS
Re: Can't run .exe files from eclipse! [message #140745 is a reply to message #140686] |
Tue, 15 March 2005 02:57   |
> it.
From a previous post:
Tore Sagen, Norway wrote:
> I'm making a HelloWorld application using WinXP and MinGW. After
compilation and linking, I select Run and Run..., then I create a new
C/C++ application. When I search my project for an executable it finds
nothing. If I try to browse for my helloworld.exe, it tells me that the
file is not executable. Neither manually selecting the file, applying
the changes and click "Run" works.
> However, if I click the helloworld.exe in Navigator or Project View,
it works as expected. Could anyone please tell me how to correct this?
Gael Martin wrote:
Your .exe are runnable dont worry :-) You just need to get the right
parser settings:
Go in your project properties dialog, click on the section "C/C++ Make
Projects", you shoud then see a tab called "Binary Parser", make sure
there's a check box next to "PE Window parser".
Gael
Re: Can't run .exe files from eclipse! [message #1860511 is a reply to message #140765] |
Thu, 10 August 2023 19:53   |
Still cant run .exe files'.
properties >Settings>BinaryParser> : Cygwin PE64 parser (checked) & PE64 windows (checked)
There are options (2nd line, filt, cygpath,& command) but what to change?
Other options for parser: mach-o 64, mach o, PE win (dep),AIX,ELF, GNU ELF ,HP-UX SOM,
Eclipse Version: 2021-06 (4.20.0)
Cliff
[Updated on: Thu, 10 August 2023 19:54] by Moderator
FUDForum. Page generated in 0.04375 seconds
